Do I have to reinstall to do a raid 0? I think so.
madcap magician
Going to set up a raid 0 and it's been such a long time since I've done one. Pretty sure i'll have to reinstall windows. Is that right?
Jason711
unless you create an image of your partition and use norton ghost..
ciscokid454
what he said, and as long as you load drivers for any new hdd hardward ie. controllers...before imaging.
If you're not changing the hdd controllers and just adding drives, then you're safe imaging, then setting up the array and imaging back to the new array.
