Happybelly
- Sep 28, 2008
I can't get any type of port forwarding or DMZ to work with this router.
I made sure to check everything in the sticky before I posted and it all checks out.
I'm using Vista, but I've tried it on a computer with XP as well. I'm using the standard windows firewall, but I also tried disabling it.
I'm using the original 1.10 firmware, I don't know if this is a known issue that was fixed or not.
Anyway, I don't know if you need anymore information. Please let me know if you do and if you have any suggestions.
Thanks.
Thanks.
