yea i know, in the good ole days, they were white, now they are a nice shade of yellow/white, lol
i think i am going to spraypaint them black, then they would look new again.
they sound great, just don't look very nice on my monitors.
i've had them for 6+years and they always work.
i cut my speaker mounts down an inch so the speakers look like they are resting on the monitors, looks much nicer, so i decided to keep them
time to break out the spray paint, then i'll post pics of the new updated ALTEC's
Have the same speakers and I have been thinking of doing the same, but wasn't sure how to keep the spraypaint off the speakers.
wow,i love it ,it's shocked and amazing, how much do you charge it??
well it's been a while but I did MANY upgrades, I now took my triple monitor stand and made it articulated, connecting it to the back wall, a little welding and I was good to go!
first I removed the 2" pipe and added an articulating arm, and a quick weld
the arm I used was for a laptop station that you can pull out.
it was connected to a tray to hold a laptop, solid steel, heavy construction. that's why I used it. not to mention it was free
the arm would not break but it would not stay supported to the wall with the extra weight.
So I welded it to a steel strip, then bolted it to my stud with 5 lag bolts.
it's not going anywhere !!!!!
by default the arm cannot be bolted as is to the wall, it's just not enough surface area, I bypassed this issue by welding it to the bar, then I have more support.
it's been on the wall for over a year now and It has not moved at all.
i'll have to see if I can find who the arm mfg is. it's all steel so it can support a heavy amount.
