for $50!
just to make sure, if i wired those two in series to get the 14.8v, then two more of those in parallel for 8ah, that pack would be chargeable with something like this, right?- http://www.batteryspace.com/smartch...polymerrechargeablebatterypack--ullisted.aspx
just making sure it will be fairly safe. i know theyre probably not-great batteries, but i need to feed about 2a @ 12v for as long as i can so i figured this might be the best route, especially since weight is a major concern. and size.
its for a diy portable windows boombox... will draw up to 4a at full volume, full system load, but mainly i think itll be around 2a on average (atom ion setup). nimh would be the better/safer route, but the price on these polymer packs is good enough that i think theyre worth considering. i would imagine around a 6 hour runtime at moderate listening levels... thats what im aiming for anyway. i dont care if it takes 5 hours to charge either, if rather have the charging safe then fast.
