Distilled Water + Few Drops of Bleach, good enough?
Discussion in 'Water Cooling' started by Peach, Feb 7, 2006.
  1. Peach
    Peach Gawd
    994
    Feb 3, 2005
    Is distilled water + a few drops of clorox bleach along with some blue food coloring good enough to keep my loop algae free?
  2. Dave332
    Dave332 [H]Lite
    79
    Jul 1, 2004
    why don't you use antifreeze or something?
  3. Peach
    Peach Gawd
    994
    Feb 3, 2005
    i dont have antifreeze available + I don't have enough money for it, i dont drive :p a friend has told me that all i need to do is make the water toxic, so nothing will grow in it
  4. Fahey
    Fahey Limp Gawd
    352
    Dec 23, 2005
    Doesnt Bleach corrod copper or something or is it something else.
  5. Peach
    Peach Gawd
    994
    Feb 3, 2005
    how about some isopropyl alcohol?
  6. Dave332
    Dave332 [H]Lite
    79
    Jul 1, 2004
    yeah, that's technically true, I just think antifreeze is the best solution for your problem - it's dual purpose and it costs like $8/gal. Anyway, if you don't have access to antifreeze, bleach is still not a great solution. You're better off with alcohol, or hydrogen peroxide, since they will cause way less damage to a system like that than bleach will. Bleach tends to react badly with a number of metals, including copper, steel, etc. which I'm sure are probably somewhere in your loop, if you used a decent waterblock and standard fittings/clamps.
  7. drizzt81
    drizzt81 [H]ardForum Junkie
    12,361
    Jan 21, 2004
    Antifreeze costs about a buck/ gallon at Walmart or smiliar places. I think you can afford that.
  8. Dave332
    Dave332 [H]Lite
    79
    Jul 1, 2004
    you're thinking of window de-icer. I was at walmart about an hour ago, and antifreeze is ~$8/gal.
  9. Justintoxicated
    Justintoxicated [H]ardForum Junkie
    14,395
    Apr 10, 2002
    you can afford liquid cooling but not antifreeze? LOL
  10. InorganicMatter
    InorganicMatter [H]ardForum Junkie
    15,352
    Oct 19, 2004
    Hey man, when you save up weeks/months for something it's not exactly nice to find that you suddenly need $20 worth of stuff you didn't account for.
  11. pigpen
    pigpen 2[H]4U
    2,408
    Aug 17, 2004
    Just use straight distilled water until you can get hold of some anti freeze to add in. Don't use bleach.
  12. Blazemore
    Blazemore [H]ard|Gawd
    1,756
    Apr 18, 2000
    ^^X10
    Take some out of your parents car radiator? Or better yet just go to an Walmart parking lot, someones POS is always leaking a little there.
  13. pigpen
    pigpen 2[H]4U
    2,408
    Aug 17, 2004
    Kind of what i was thinking ;)
    Parents have some in the garage?
    Get some from a friend?
    You only need like a dixie cup full, not that much to ask.
  14. Justintoxicated
    14,395
    Apr 10, 2002
    you mean $8 of stuff right? :p
  15. NortHWizarD
    NortHWizarD [H]Lite
    109
    Aug 31, 2005
    If you saved up that long, why would you now rush it and not do it the right way, like everyone is suggesting... the cost is extremely minor, it's the right way to do it... and you have spent good money on the system... are you willing to chance damaging the system you saved up for week/months for just because you are impatient and won't drop a couple bucks to do things the right way
    ~NortH~
  16. CRXican
    CRXican [H]ard|Gawd
    1,962
    Jul 28, 2004
    If you don't even have $20 to spend then you probably should have bought food instead of trying to water cool a PC with bleach water.
  17. killernoodle
    killernoodle 2[H]4U
    2,634
    Aug 4, 2002
    Just run straight distilled water until you can afford to put some antifreeze in there. :rolleyes:
  18. malicious
    malicious [H]ardness Supreme
    4,772
    Apr 8, 2005
    i bought 16oz of pentosin blue from a guy in fs forum for 10 bucks shipped..
    not putting antifreeze in the loop is penny wise and pound foolish
    you have to worry about corrosion also .. not just the nasties
    antifreeze is toxic and anticorrosive ..
    you only need about 2-3 oz of it ... see if anybody has any in their garage
  19. malicious
    4,772
    Apr 8, 2005
    qft
  20. Majin
    Majin 2[H]4U
    2,477
    Feb 4, 2005
    HEY BACK OFF!
    If OCing a PC with a new WC set up, instead of eating isn't [H]ard, I don't want to know what is!
  21. Peach
    Peach Gawd
    994
    Feb 3, 2005
    I'm only 17 :rolleyes: and in-between jobs and needed a quick fix, i understand that anti-freeze is the way to go, i'll try to pick up some this weekend, until then im running it with a little less than a cup of isopropyl alcohol + distilled water + blue dye, it looks alot better than those nasty green thermaltake tubing :D
  22. BioPort
    BioPort Gawd
    754
    Oct 6, 2004
    dude is probably like 15.
  23. TheToE!
    TheToE! [H] Brewmaster
    6,801
    May 17, 2005
    Anything worth doing is worth doing right. Get some coolant. You'll want to be carefull about what you put in your loop. For one thing, im not sure I would want bleach going through my pump, not to metion the reaction it could have with other materials. I would shy away from putting household chemicals in the loop.
  24. kemist1117
    kemist1117 Limp Gawd
    502
    Dec 1, 2005
    isopropyl aint bad, but if you have plexi in your loop it will crack it so you need to get rid of it if you do.
  25. Lord of Shadows
    Lord of Shadows 2[H]4U
    3,318
    Mar 9, 2004
    Dont put bleach into your water cooling setup, speeds corrosion and I believe it can even deteriorate your tubing.
  26. nobody_here
    nobody_here [H]ardForum Junkie
    8,878
    Feb 1, 2006
    small bottle of Algae Destroyer(for aquariums) costs $3 to $4, just add a few drops and it wont grow, add as you see the need
  27. xdkimx
    xdkimx Limp Gawd
    443
    Jul 17, 2005
  28. Chernobyl1
    Chernobyl1 [H]ard|Gawd
    1,674
    Jun 19, 2004
    I use a few drops of washing up liquid.
    It has worked wonders, I had no algae ever despite using clear tubing by a window for a year!
    Its also a good water wetter/surfactant.
  29. EQDuffy
    EQDuffy [H]Lite
    87
    Apr 16, 2003
    Bleach is BAD for water loops. Just don't do it.
  30. masher
    masher [H]ard|Gawd
    1,155
    Jan 31, 2005
    I hope you don't have any dissimilar metals in your loop.
  31. EQDuffy
    EQDuffy [H]Lite
    87
    Apr 16, 2003
    Which is a pretty big long shot, heh.
  32. NACZ3
    NACZ3 Gawd
    538
    Mar 5, 2004
    Do not use bleach in your loop, it may kill off any biological growth in the water but chlorine is corrosive to metals. You can get pitting from it and over time maybe a small hole. Just use some car antifreeze if you on a budget, look for some on special or hell, siphon some out of your car :)
