"Disk boot failure" - hard drive failing?
Discussion in 'Operating Systems' started by rygy, Jul 17, 2006.
  1. rygy
    rygy Limp Gawd
    448
    Jun 19, 2003
    Hi, I am trying to diagnose a problem with a computer I offered to "fix". The owner was unable to load Windows XP withotu having the XP install disk in the drive. The OS would load and run fine as long as the computer booted with the CD in the drive. I partitioned the drive, copied the personal files to the new partition and formatted and installed XP on the first partition. I encountered one problem while installing and it was along the lines of:
    "IRQL_DRIVER_IS_NOT_LESS_THAN_OR_EQUAL"
    Which would appear in a BSOD during the Windows install.
    I swapped out the RAM and was able to complete the install. Now, on a fresh installation I am getting this error:
    "DISK BOOT FAILURE. PLEASE INSERT SYSTEM DISK AND PRESS ENTER"
    when I don't have the XP install disk in the drive.
    Does this mean that the hard drive is probably dying? When the XP disk is in the drive the computer runs fine. It's also crazy that both the memory and the hard drive would fail at the same time.
  2. rygy
    rygy Limp Gawd
    448
    Jun 19, 2003
    Is it possible to fix the boot sectors on a drive? Are the boot sectors something that gets reformatted when I reformat the entire drive?
  3. missionzero00
    missionzero00 n00b
    53
    Apr 3, 2006
    You can fix boot sectors using recovery console. look at fix mbr and fixboot.
  4. rygy
    rygy Limp Gawd
    448
    Jun 19, 2003
    I disconnected the CD drive and connected the hard drive to IDE2 (the connector the CD drive was on) and set my boot order and Windows loaded fine. Is it probably a problem with the IDE controller then?
  5. -(Xyphox)-
    -(Xyphox)- [H]ardness Supreme
    6,525
    Sep 9, 2004
    i would goto xp repair center do a chkdsk /r than a fixboot fixmbr
  6. Wingy
    Wingy [H]ard|Gawd
    1,294
    Dec 18, 2000
    Does the CD drive work? If it doesn't work on IDE1, I would say you are correct.
