Like the title says. Is it possible to have all USB storage devices diabled (ie: if you plug in a flash drive or a USB disk, it just won't work while it would work if a USB mouse is plugged), however, if storage device A is plugged in, it will get detected/identified and work just fine?
OS is windows 7 and XP
I hope I made myself clear.
Thanks in advanced.
Thanks in advanced.
