I have a situation where we are running Windows XP/SP2 and have the VMWare Player application running an instance of NT4.
This is due to the fact we have a VERY old antiquated program that only runs on NT4 (boo hoo for us).
We've got the app working in the VMWare instance just fine. But I would like to disable Internet Explorer in the NT4 portion.
I've done some google searching and have found lots of "messy" ways. I'm thinking of quick and easy. The thought of just renaming iexplore.exe has come up as the easiest and I might go down that road but I wanted some opinions here first.
So bust out your "Way back when" hats and see what you can come up with.
The users will NOT be local Admins on there XP or NT portions so we won't have to worry about that. I'm also pondering providing NO Proxy connection information so the only sites that would work would be internal ones and that would be fine. Maybe that's my answer.
Thanks guys
Thanks guys
