GotNoRice
- Jul 11, 2001
I've noticed that when you have a 64-bit program, and try to enable the "Disable desktop composition" option in the compatibility tab of the options, it simply does nothing (doesn't disable desktop composition).
Doing this with a 32-bit app/game works as intended.
I just got a GTX680, and I'm trying to work around the known bug that is causing my 2nd monitor to go black every time I launch a game with Aero enabled. The easiest way to do this is to select the "disable desktop composition" option for each game that I play. But some of the games I play now use 64-bit executables.
