Directron Hot Deals - 12/5/2011
Directron
12/14 - 12/19
Thermalright Silver Arrow Dual Fan CPU Cooler, for Intel Socket 1366/1156/1155/775 and AMD Socket AM2/AM3 CPUs
Regularly: $74.99
Coupon: $7 [ hard72211b ] Expires 8/12
$67.99
AMD Phenom II X6 1055T Thuban 2.8GHz 4000MHz Socket AM3 Six-Core 45nm Processor HDT55TFBGRBOX, Retail Box
$159.99, Free Shipping
hard112811a - $22 off
$137.99 after coupon & Free Shipping
Noctua 120mm and 140mm SSO CPU Cooler, for Intel Socket LGA1366, LGA1156, LGA775 and AMD Socket AM2, AM2+, AM3 Processors, Model: NH-D14
Regularly: $89.99
On Sale: $79.99
Coupon: hard1252011c ($12 off)
$67.99
ASUS P8Z68-V LX Intel Z68 Socket H2 ATX Motherboard, Support Intel Core i7 / i5 / i3 LGA1155 CPUs, Dual DDR3 2200(O.C.), SATA III RAID, Gigabit LAN, USB3.0, DVI, HDMI
Reguarly: $129.99
On Sale: $119.99
Coupon: hard12152011b ($15 off)
$104.99
ASUS P8Z68-V PRO/GEN3 Intel Z68 Socket H2 ATX Motherboard, Support Intel Core i7 / i5 / i3 / Pentium / Celeron LGA1155 CPUs, Dual DDR3 2200(O.C.), SATA III RAID, PCI-E3.0, USB3.0, DVI, HDMI
Regularly: $219.99
On Sale: $207.99
$192.99
ASUS SABERTOOTH X79 Intel X79 ATX Motherboard, Supports Intel Core i7 LGA2011 CPUs, Quad DDR3 1866, SATA III RAID, PCI-E3.0, eSATA III, IEEE1394, USB3.0, Gigabit LAN, Quad-GPU CrossFireX / SLI
Regularly: $339.99
On Sale: $329.99
Coupon: hard12152011c ($10 off)
$319.99
General Coupons:
hardocpsanta2 - 2% any order of $60 or more. Orders placed will coupon will automatically receive a free travel mug with their order. Style may vary slightly for the mug but will generally look similar to:
http://www.directron.com/intelcup.html
hardship2 - Free UPS Ground Shipping for orders of $150 or more. If shipping air then it will apply a $5 discount instead. The cup will also automatically be added with this code.
(note the cup won't show in your basket, it's added during processing)
Coupons expire December 12 unless otherwise listed
Also feel free to check out the Red Tag sale going on now:
http://www.directron.com/redtagevent.html?hardocp=1 (122 deals)
Patriot Warp 128GB 2.5in SATA II Solid State Drive (SSD), Model: PE128GS25SSDR
$119.99
Patriot 32GB 2.5in SATA II MLC SSD (Solid State Drive), Refurbished. Model: RF32GS25SSDR
$32.99
Coupon: hard1252011a ($3 off)
$29.99
Noctua CPU Cooler NH-C14 for Intel LGA1366, LGA1156, LGA1155, LGA775 and AMD AM2, AM2+, AM3 CPUs, with Dual SSO-Bearing Fans
Regularly: $89.99
On Sale: $74.99
Coupon: hard1252011b (10% off each)
$67.49
Regularly: $89.99
On Sale: $79.99
$67.99
Samsung Spinpoint F4EG 3.5in 2TB SATA 3.0Gb/s Internal Hard Drive HD204UI, 5400RPM, 32MB Cache. OEM
Regularly: $259.99
On Sale: $209.99
Coupon: hard1252011d ($40 off)
$169.99
General coupons
hardfree = Free shipping for orders of $100 or more
And now for a twist
hardsecretsanta - 2% off your entire order + A mystery gift (Min $80 order)
hardsecretship - Free ground shipping off your entire order + A mystery gift (Min $240 order)
So what's the mystery gift? That's a mystery. If you order using one of the two secret codes you'll get something free added to your order at processing time. What is it? I can't tell you, It's a suprise. Most items are valued between $5 - $20.
(Note: won't be lame ground coffee. You might get a travel mug or something though.)
Also taking requests for later hot deals / next sale.
Next deals start 12/14/2011
syn0s
GPU deals for next sale/christmas sale please!
Also, want a logitech G13 and maybe another Corsair Hydro cooler deal
DuronClocker
Can't find any information on that 32GB SSD. I had a PS-100 a while back that was less than stellar, though for what I'd use it for now, it wouldn't have to be insanely fast.
Is RF32GS25SSDR just a refurbished PS32GS25SSDR?
EDIT: Looks like the specs (175/100) match more closely to the Warp series PE32GS25SSDR except for SLC vs. MLC
Directron
Not sure if that's the exact part number but yes. PS100 isn't the right one though I don't think
Edit: Yes, I believe it's a warp.
I actually personally snagged one of the 32GB drives to use w/ a Vantec 2.5" USB 2.0 + eSATA enclosure http://www.directron.com/nst200subk.html
It's rocking for a part time drive for a Boxee Box. @ The price vs performance ratio it's better for that than a 32GB SDHC card.
-Lee
DuronClocker
Oooh, that might work out even better for me in that case because using eSATA over SATA in my situation would simplify my life quite a bit. To use that enclosure as eSATA, what do I do for power? Does it require the USB to be plugged in still for power?
Directron
Yeah it leeches power off the USB connector - - but it's the split Y kind, when you use eSATA you only need to hook up part of the Y iirc.
Directron
If you are serious -- that's probably not going to work out too well. Selling very fast. Only 4 Left for that one. I believe it's a 1 time deal for that particular model. (Patriot is clearing out for new models. )
The 4 remaining probably won't make it past the end of the day.
If you want a low value coupon try super50 - ($1 off $50 or more)
ninehunid
http://hardforum.com/showthread.php?t=1656405
mine showed up as a ps-100 in windows 7
piratepress
Anyone have one of those 128GB Patriot Warp SSDs? I'm tempted by the price but looked around and found this:
Pros:
- Good Price for 128GB SSD
- Very good performance
- Light Weight
- Silent
- Vibration Resistant
Cons:
- While decent 2 year warranty is still 1 year too short
- Not as good as the X-25 (or spindle drives in certain write tests)
- Potentially slow writes
- Stutter problems which need extensive tweaks to alleviate (but when done make for one great SSD experience)
Jesus_Faction
Ok, you got me. In for one.
D
Deleted member 176933
Guest
@directron
1. secretsanta coupon isn't working
2. have y'all considered selling the fractal design cases?
3. If I order something listed as drop-ship only, but select Store Pickup...how is shipping handled? Would it be like walmart's free ship-to-store?
psychogee4o8
doctah,
regarding question 2, let's call it a rumor, but i think fractal design and newegg have a contract til the end of this year that they'll be the only US supplier. So this years almost ending.
Directron,
I too am in the market for another fractal design case on top of the 1155 motherboard. so I too would like that question answered.
Directron
1) Sorry about that, I had originally intended to end the secret santa early for fulfillment reasons but forgot to note the expiration date on the post. I went ahead and just re-activated it now so it's good until the 12th.
2) I believe that brand is exclusive at the moment. We are unable to offer them right now. Not really sure when / if that will change. Maybe sometime after CES.
3) Kind of like site to store. if you order a drop ship, and it's pickup then we'll ship in the item as long as the order is paid for. You'll be able to then pick it up in the show room w/o paying shipping costs. If you are wanting to pay cash for the order you have to come by and pay for it first before it gets shipped in though. Depending on what you order it may take 1 - 4 businesses days to be ready for pickup for a drop ship (depends where it's coming from and when you order).
4) Will try and put some 1155 stuff in the next sale / deals.
PCduster
@Directron
Do you guys actually have the Corsair Vengeance K90 keyboard in stock? If so, I would say that is a pretty decent deal, considering your price is about 10 bucks cheaper than the only other place in the US that I have seen them in stock at.
The thing is, there are a handful of websites out there that say that they have them in stock, or that they will be available soon, but I only just was able to complete an order for one today with a place that was able to verify that they had them.
Directron
Sorry we had some initial stuff but it's gone, and even Corsair doesn't have any at the moment. We've closed the item (it won't add to cart).
Directron
so far-
12/14 - 12/19
Regularly: $74.99
$67.99
Regularly: $89.99
On Sale: $79.99
$67.99
Reguarly: $129.99
On Sale: $119.99
$104.99
Regularly: $219.99
On Sale: $207.99
$192.99
New thread--
http://hardforum.com/showthread.php?t=1659336
