For those who are concerned about the lack of OSD. It would be incredibly expensive to implement a OSD at this resolution and it is also unnecessary. Only brightness can be adjusted by a simple push of a button which works effectively. Nvidia / AMD / Intel control panel has all the options necessary to adjust color, contrast, and also takes care of scaling settings. I also have the 30 inch LCD 16:10 model which I still use today. Using the GPU software to adjust monitor settings is better than dealing with annoying an annoying OSD. You can save profiles in a control panel and change on the fly.
... Wait what? I'm pretty sure this thing was retailing around the same prices as other mainstream monitors. I wouldn't doubt it was actually more expensive than the Asus PB278Q, but the latter has an OSD.
...which doesn't matter to me since I'm probably going to have a service take off the antiglare (and possibly debezel) anyway.
Without even doing research I'm sure the Asus model was always priced higher.
Great to hear that. How much did they charge for this $300 monitor?^^ Yep. A squaretrade rep just confirmed to me via chat that they would cover it.
At this point, I may say the hell w/ OC'ability and get this for the cheap. It'd cost me the same as my GTX 770 (before warranty purchase).![]()
Not too bad, so $340 for an allegedly new HP monitor and warranty, which is still a bit cheaper than the $350 monitor that occasionally comes on sale at Woot for a refurbished HP.I think it was ~$40.
In response to warranty, please note that these are probably the original ZR2740w models (not v2), issued beginning in 2011. This means that their original 3-year manufacturer warranty may either have expired or is about to expire, which is why Directron may be guaranteeing them for 1yr. This is most likely a clearance sale of inventory in "New" condition which has gone unsold for too long.
The only difference between ZR2740w v1 and ZR2740w v2 seems to be antiglare coating (v2 having the slightly better, less obstructive coating), which doesn't matter to me since I'm probably going to have a service take off the antiglare (and possibly debezel) anyway. Even for those keeping the coating, the difference between both isn't worth crying about, and you'd only really notice it if you had one of each side by side anyway. It's a small improvement yes, but not night and day enough to pass up on this insane price.
Review of v2: http://www.tftcentral.co.uk/reviews/hp_zr2740w_v2.htm
But if I receive v2s when they arrive instead of v1s, even better ;-)
Not sure if you're talking about TN 4K monitors, but the ZR2740w is IPS, not TN >_>
See:
http://www.tftcentral.co.uk/reviews/hp_zr2740w.htm
http://h20566.www2.hp.com/portal/site/hpsc/public/psi/home/?sp4ts.oid=5163694
Huh? A manufacturer warranty is never dependent on manufacture date, just when its sold to the end user. It is an older model though so maybe HP has a new 27" model coming soon.
You're in the same boat as me. I also have a 24" Dell LCD with 1920x1200 (thankfully not the short 1080 stuff). But my monitor is even older, from 2005.Really tempting. How are you guys liking this as far as color reproduction?
I currently have a DELL 24" IPS (2408WFP). It's 1920x1200. Might dump that for this.
Obviously 4k is coming, but I don't see myself buying a GFX card capable of driving 4k games. I could upscale 1080p. But what's the point? Unless it's a 32"+, it's no real point to it.
Could you maybe confirm the manufacture date and check the warranty status on this site?Got mine today...
You should be able to get service based on S/N alone, I've had one replaced that was purchased secondhand (ie, no receipt.) The receipt would come into play if your purchase date (for a legitimately new unit) was much later than the manufacture date. Support on the Z-series stuff is pretty great once you get to the right department. (The standard outsourced consumer support is abysmal and has no clue how to deal with these.)Huh? A manufacturer warranty is never dependent on manufacture date, just when its sold to the end user.
They already have one, the Z27i.It is an older model though so maybe HP has a new 27" model coming soon.
(Info is on a small panel that pulls out of the left edge of the bezel.)
http://h20566.www2.hp.com/portal/site/hpsc/public/wc/home?
I would expect these to have at minimum the balance of factory warranty remaining based on the S/N, regardless of what the Directron site says. Unless HP "blacklisted" the serials or something which would seem odd.
It retails for $769....
I can answer the first part of this. My 2.x-year old ZR2740w started failing recently. It would just go dark, seemed to be overheating. After going through HP's typically complicated process of creating an account on their site, I opened a case. No response. Three days later, my doorbell rings at 8am. Open door, replacement monitor with return shipping label.how's hp's warranty process? Dell is pretty painless on their premium monitors. Will hp ship you a new monitor first if this one has defects (dead pixels, bad backlight bleeding)?
I'll check that out when I get home. Only 7.5hours left....
So they should be the V2 with less harsh AG coating. The shorter warranty is for initial setup support which is irrelevant; the replacement through 2017 makes it a pretty awesome deal.Manufactured March 2013.
Has two warranties that are "Active" one ends May 23, 2014 and the other on Feb 22, 2017.
The one ending in Feb 2017 is "Wty: HP HW Replacement Support."
In that case, I guess no extended warranty (like from Square Trade) would be needed?So they should be the V2 with less harsh AG coating. The shorter warranty is for initial setup support which is irrelevant; the replacement through 2017 makes it a pretty awesome deal.
