I know this is probably asked a lot, too much even, but I keep getting mixed answers by searching online. If I have a wireless router, what would be the difference in setting it to either Bridge mode or as a Repeater mode? I believe bridge mode would have it catch a wifi signal and allow you to hardwire a device to it via ethernet, right? And i believe repeater mode would have the router catch a wifi signal and... repeat it... amplify and send out the wifi signal to extend the wifi range coverage, right? Now, i dont see why both have to exist. Cant you set the router to repeater mode and still hardwire a device to it via ethernet, while still having it broadcast the repeated wifi signal?
Also, would a router set to bridge mode re-broadcast the wifi signal too while still having a device connected to it via ethernet?
Lastly, what if you set the router as an AP? Dont AP's extend the wifi coverage by re-broadcasting the connected wifi signal, AND allow you to connect devices via ethernet?
Any help and feedback is greatly appreciated.
