TaintedSquirrel
- Aug 5, 2013
The servers were rebooted yesterday to fix an mtx bug. Everyone was kicked. Looks like it may have happened twice.
My son is running a similar setup and he's on medium settings, running it just fine.Been playing on PS5 but want to jump on my pc. Have a 34" Ultrawide 3440x1440 100hz. Running a 2070 super and a 5800x3d. Think my 2070 super well hang or is it time to upgrade? I like the eye candy![]()
The game has been proven to run incredibly well on older hardware. I suspect you may even be able to run it on high graphics settings as well and still maintain excellent FPS.My son is running a similar setup and he's on medium settings, running it just fine.
Yeah, the lighting is really nice. I just hope other classes get light effects at least later on. Hydra was useful in the server slam to just light an area to see better...I put my Rogue aside doing Fire Sorcery with Arc Lash also did a Druid I like how big she is but not sure how it would be End Game always transforming into a Bear must suck after a while. I think I'll stick with the Mage because the Rouge just looks boring with the same attacks. The thing I like about the Mage the elementals she casts light up the Hallways.
Just cap your FPS to something lower and it will cut the heat down a lot. And/or lower a few settings.View attachment 574947
It's a OK game but I'm not really impressed so far I played better games 23 years ago but it's good. The problem I have with the game they played it SAFE it feels like a safe game not dying wise but with the overall design feels too safe. It has the typical flaws of any Top Down Action RPG enemies just rush you the special enemies is where the game shines it changes up the pacing. This game is made for a Mage I don't think I would enjoy any other class.
I know I'll like BG3 over this game just due to the pacing with that game plus it's cheaper. V Rising is way more complex and fun than this game....
This game turns your Room into HELL with your PC putting out more heat than a Supernova.
Don't you have to select DLSS under that that option instead of the Ultra High? Also, what cpu cooler do you have?I'm playing Ultra highest settings @ 3440 X 1440 res 175hz, and it plays smooth as butter, zero hiccups. My CPU temp ranges in the 40c to 45c while playing.
Yes, I noticed the heat output while running the game. I had to turn on my ceiling fan, the room was cooking and I had the door open and Air on...View attachment 574947
I'm capped at 60 FPS due to the cheeze nature of the TV I'm playing it on (can't argue, I paid 200 bucks for a 55" 4K). It's still dumping an assload of heat into the room. Not even Cyberpunk does that...Just cap your FPS to something lower and it will cut the heat down a lot. And/or lower a few settings.
Probably need to lower a few settings then. I'm on high settings @ 1440p (3080) getting fps in the 100-200 range and heat output seems pretty normal. Get more from jedi survivor/DS remake.I'm capped at 60 FPS due to the cheeze nature of the TV I'm playing it on (can't argue, I paid 200 bucks for a 55" 4K). It's still dumping an assload of heat into the room. Not even Cyberpunk does that...
I had everything maxed on Jedi Survivor + RT and my room never got hot. This game just cranks the heat out like crazy. I am running all settings maxed, it never drops below 60fps. If I'm still playing this upcoming winter it will be a nice space heater.Probably need to lower a few settings then. I'm on high settings @ 1440p (3080) getting fps in the 100-200 range and heat output seems pretty normal. Get more from jedi survivor/DS remake.
It's enabled by default on NVIDIA cards when you start the game the first time. It's under a separate category in the options called "Performance" in the Graphics tab. I'm pretty sure that setting isn't tied to the Quality presets.I never run DLSS, hate that stuff. But is it somehow enabled by accident? I just have the preset for Ultra / Highest on, and scrolled down the list which shows every setting maxed out.
Kraken Elite 360 CPU cooler
In the game. Graphics tab, Performance category. The resolution scaling and temporal AA options are also there. If you enabled DLAA in the game, it will turn off DLSS automatically.Is that a setting option in the nVidia CP? Or in game setting.
I want that off.
Jedi Survivor is poorly optimized for PC and doesn't stress your video card. With Diablo 4 the best suggestion is to cap frames if you're using a monitor with a high refresh rate.I had everything maxed on Jedi Survivor + RT and my room never got hot. This game just cranks the heat out like crazy. I am running all settings maxed, it never drops below 60fps. If I'm still playing this upcoming winter it will be a nice space heater.
I don't have a high refresh monitor. Just 60 FPS. I think the discussion wasn't so much that we were complaining about the heat as we were just stating that it was a factor.Jedi Survivor is poorly optimized for PC and doesn't stress your video card. With Diablo 4 the best suggestion is to cap frames if you're using a monitor with a high refresh rate.
It will run fineBeen playing on PS5 but want to jump on my pc. Have a 34" Ultrawide 3440x1440 100hz. Running a 2070 super and a 5800x3d. Think my 2070 super well hang or is it time to upgrade? I like the eye candy![]()
Not bad, frame gen seems interesting for 4k on a 4070 maybe? This game runs so well you wont need it on the 70ti and above. I'm absolutely blasting it on the 7900 XTX at 4k
DLAA if you want the highest quality. DLSS is recommended if you need to improve your framerate with minimal loss in image quality. If you're not having performance issues, then DLAA will greatly improve the image quality with minimal performance impact.So again, what are the recommended settings for the best graphics? Ultra or DLSS? I thought the DLSS was highly recommended.
Looks like the game benefits greatly from SMT/HT.
there's no motion blur with or without that optionDon't forget to disable motion blur! It's disguised as distortion.
What level are you? Some people hit level 40 before finishing Act 1FINALLY finished Act One. Finally.
There's no reason to rush it, go at your own pace.FINALLY finished Act One. Finally.
Really? I turned it off an noticed a difference.there's no motion blur with or without that option
Well I'm playing a Necromancer and it took me a LONG time to figure out the build. Lvl 24 now.There's no reason to rush it, go at your own pace.
He's talking about the dual blades build...it is that retarded honestly. As a L50 I'm mowing through L53 mobs like that don't exist. Its going to get a major nerf at some point.
https://maxroll.gg/d4/build-guides/twisting-blades-rogue-leveling-guideCan you share the build?
The Dual Blades?Can you share the build?
I was level 36. Oops, now i want the mount so getting back on track.What level are you? Some people hit level 40 before finishing Act 1![]()
I've got the fast enough computer. I want the highest quality best image
Quality preset ultra
Nvidia DLSS Off
HDR enabled
I'm not a big fan of Nvidia filtering like DLSS I much rather use the brute force method of just having a fast rig to power the game at max settings with no trickery.
Do I have this correct?
If you can run a game native resolution and the game supports DLAA - Use it. It's an amazing technology.I've got the fast enough computer. I want the highest quality best image
Nvidia DLSS Off
HDR enabled
