Can someone copy/paste the path notes in here? DH's finally got some love? I have a 69 DH that I never bothered to continue playing because i got sick of the silly balance decisions.
DH's got a lot of love, basically they lost the poison element, everything has boosted weapon DPS, and converted some things to fire and cold elements.
https://us.battle.net/d3/en/blog/15487814/patch-210-now-live-8-26-2014#dh
So it seems Wizards are broken. From what I read, they were perfectly fine in PTR with the exception of a bug(Energy Twister?) but they broke Firebirds and Hydra's right before releasing the patch. Seriously, why do they even do a PTR if they are not gonna listen and just break everything before releasing it? All while not caring about Demon Hunters steamrolling through everything. But let's make sure wizards aren't too OP :roll eyes:
I wonder why they keep the healing/defense moves a static number and just keep buffing them over time? Why not make them scale somehow? i.e. Damage absorption increased from 71798 to 93337
They do scale. The number they report in the update notes for level 70. You're obviously going to have less at lower levels otherwise you could steamroll while in the process of leveling by yourself.I wonder why they keep the healing/defense moves a static number and just keep buffing them over time? Why not make them scale somehow? i.e. Damage absorption increased from 71798 to 93337
Not really sure what you are talking about my Wizard steam rolled everything just fine. 100 million crits with my meteor. Didn't they already patch in fixes for FireBirds?
My only problem now is I was a fire wizard and now that the Arcane Meteor is completely bad ass I'm going to have to change my element to Arcane.
My Star Pact does 2740% damage with 60% on top of that for arcane dynamo.
What's firebirds? Never heard of that before.
Ah, gotcha.He means scaling from like L70 Normal content to L70 Tier 30+ GRifts.
It's a set for Wizards that, among other things, has a set bonus that gives a revive when you die. It's called Firebird's Finery.What's firebirds? Never heard of that before.
On what torment? I steamroll through T4 as well, T5 isn't too hard either with a group that can tank some damage. The problem is when the stack damage from Firebirds doesn't work correctly and I'm stuck with something like 20 million damage per second on a 5+ billion HP RG instead of 100 million. Hydras are not affected by any IAS, CHD, CHC or +hydra damage which is annoying since they could be doing more damage. They also don't seem to proc firebirds correctly(the Mammoth hydras that is)
Well I don't use Firebirds but this was posted by a blue a while ago.
'Quick update! The hotfix for the Firebird's Finery set has gone live, and the 6-piece set bonus has been enabled. Thanks again for your patience, everyone.'
Tal rasha's set seems to bee better IMO. Dropping a meteor each time you use a particular element seems awesome. Only need 1 more set or the ring to have it.
RoS 6 piece wizard set. http://diablo.wikia.com/wiki/Firebird's_Finery
http://us.battle.net/d3/en/profile/Krieg1337-1699/hero/10289552
My profile shows the correct/new 6 set bonus.
They activated the 6 set bonus but they CHANGED it from the PTR and the change is not working correctly.
Tal Rasha's is pretty good, only problem is you can't focus on any one element really since you want to use Cold/Lightning/fire/Arcane to get the meteors. Elemental Exposure works really well with it though.
Well Fire is still the strongest element right now for wizards, arcane is still pretty good as well.
all are strong. It just depends on play style. I was using Fire Nova and Fire blades and it was great....but the new Star Pact meteor is perfect for how I like to play. Just love boosting Arcane Dynamo and Dropping 1 meteor for 2700% weapon damage and seeing the 100+ million crits. Even Higher on elite packs too from my 57% elite damage.
I am so confused as to how people are getting 100million crits with meteor and Hydra.
Currently using a MM, Black Hole, and Meteor shower build. I spam meteor until no Arcane, then MM, repeat. Drop black hole when off CD.
I have not seen any 100 Million criticals, on 10 Mil +.
I just bought Diablo ]l[ and 'Reaper of Souls'
First time playing both. Is there a way for me to start right on the Reaper of Souls expansion game, and not have to go through the original Diablo 3 game first ?
So it seems GR guardians have a 100% drop rate for either 1 or 2 legendaries (plus a gem).
This is all GR's, including GR1.
So if you start on GR1, clear the rift, then wait until 4:00 remains you can kill the boss, get the items, and it will only bump you +1 rank.
Not really "amazing" but it's an easy way to get some free legs.
Example: http://i.imgur.com/bjAol5W.png (Notice Greater Rift Rank 7).
I got 2 legs + 1 set piece! And a leg gem of course.
I believe I'm done with my WD. Just feels boring to me now. Guess it's what I exclusively played from ROS launch. Trying to decide between my monk or DH. LEaning monk cause it was my d3 vanilla main and I have never really played DH.
Open to comments to convince me to play DH though.
