http://xtremesystems.org/forums/showthread.php?t=139778
Someone has the DFI 680i LT motherboard...and he's testing it out. Check it out.
OOOOO
I wonder then the regular 680 LPs will arrive!
I've read unconfirmed reports that DFI will not be doing a non-LT 680i-based motherboard. The presumed reason is because the 680i LT may not suffer from some of the erratic, odd behavior that some are inexplicably having with the non-LT 680i chipset.
Don't shoot the messenger. I did say these reports are unconfirmed.
I am at a point now where I really feel like a program (similar to memtest) needs to be intgrated into bios that will do a torture test on the memory, cpu, pcie, fsb to find the most optimal settings.
Any updates?
If you follow the link in the OP, and read all the pages in that thread, you'll see that the quad does not overclock very well yet on that mobo. They're speculating that a bios update will improve the overclockability of the quad cores (like the P27 bios for the evga mobo's).Being a longtime DFI user, can't wait to hear how this board runs and OC's. Although I'm happy with my current rig running E6600, I may have to give the IN9-32X Max to my son if this DFI runs like my ol' AMD64 DFI's ran. and spring for QUAD. Although Abit finally got the BIOS fix to run all four Cores OC'd on a QUAD.
Which, the DFI or the Abit IN9-32X Max ).
