Desktop won't post or boot properly without pressing the reset or power button
AMD_RULES
I'm not sure if I'm experiencing slow hardware failure or what, but with my sig desktop every time I turn it on... it won't post. I have to press the power button and/or reset buttons a few times before it will finally post.
What could be causing this? I've tried resetting and clearing the CMOS, as well as checking to make sure everything is properly sitting in the motherboard (graphics, wifi, ram, etc).
Thank you!
Have you checked to make sure all of your power cables are properly connected and not loose at all? Also, when did this problem first start and how long has it been happening for?
Well this first started happening after I reinstalled Windows 7. I installed the lastest drivers and I think that solved the issue. I'm going to run some benchmark software to test for stability.
