Bladestorm
- Dec 10, 2006
Is there a good way to get a DEMCiflex magnetic filter to stick to an aluminum case? I've got two 92mm intake fans on the under side of a case, and a dual 92mm DEMCiflex filter on order. I thought about sourcing some thin steel tape, and trimming it to the dimensions of the perimeter of the filter. Would that work, or should I just glue it?
