enyceexdanny said:25% off LCD coupon
1P5JXHTM90LW3C
james__bean said:25% off any Dell Flat Panel
Code: 1R24DHWG6LFHLP
james__bean said:Just so you know though, they don't actually check the email addresses. Just hit back, change a letter in your registration email address and keep playing.
yippiekiyeh said:So what happens if you actually WIN something?
If the prize is over a certain amount, they email you an affidavit that you have to print, sign, and return. They have no way of knowing your address is right, so they are not going to just send a prize to some address without knowing that the address is correct. I'm pretty sure they thought of the possibility of false addressess(both physical and email) before the contest went live.james__bean said:Well your address is right, so they might still send it to you.![]()
aren't some dell lcd's just rebranded samsung? might be worth a looksativa said:crap i wish the 25% off stuff worked for Samsung panels. I'm getting a 710T soon, but should i just go with a dell?
