Dell vs Ghost 2003
I have a brand new Dell Dimension 3100 here. In a quest for
an invincable backup solution the very first thing I did was
install Ghost 2003 to burn an image of the C drive to DVD.
I've been using Ghost for years and have never had an issue with
it. I have used it on several Dell machines in the past as well.
However, this time around the Ghost operation failed to complete
and I am now stuck in an endless cycle. I've called Dell Support and
(half an hour later) was given what I thought would be the magic
bullet: Ctrl+F11. This should take me to a menu where I can at
least reinstall the OS. The problem is that Ghost supercedes
even this command and I cannot get into the recovery menu.
I tried setting the 1st boot device to CD/DVD to run a bootable
Ghost CD ... and it almost starts ... then hangs.
Dell Support eventually conceded that Ghost 2003 may have issues
with their PC Restore utility -- which just happens to be another
Symantec product.
The Symantec Support phone # I was given by Dell is no longer in
use. :-/
So I searched the Symantec site for a solution -- found another
magic bullet -- instructions to elleviate the problem by running
ghreboot.exe.
Soooo, I rebooted the machine, the Ghost operation starts and I hit
F1 to take me to a prompt. The instruction was simple: To bypass the
Ghost operation, type 'ghreboot' and hit Enter.
Guess what? The screen hangs and does NOT take me to Windows.
If anyone can offer a solution I haven't tried, I am all ears.
Thanks!
Symantec product.
use. :-/
ghreboot.exe.
Thanks!
