http://www.techradar.com/reviews/pc...rs/dell-up3017q-oled-4k-monitor-1311504/revie
Hopefully oled monitors will go down in price quick like the 4k monitors did.
Why the hell is this [so much] more expensive than a 55" LG OLED 4K TV???
Because anything labeled monitor instead of tv is always priced more expensive.
I want this so bad! I wish lg would do a 48" or 40" oled 4k tv, I'd buy one if they did, it would be cheaper than this dell too.
I would believe it's more expensive primarily because the smaller size leads to a higher density of pixels, which can lead to tighter manufacturing tolerances. PC displays also need their boards designed differently to prioritize the uses and concerns one will have over a television. It's taken so long to see an OLED monitor because of the burn-in issue, as PCs deal with a lot of static images on screen for long periods of time when in use.Why the hell is this [so much] more expensive than a 55" LG OLED 4K TV???
EDIT: Also, who made this panel? LG?
Is it wrong that I want this to have freesync with a range of 30HZ to 120Hz to annoy nvidia people? Am I a bad person?
fanboy does not equal to bad person
This must be the first DP 1.3 monitor as well? Since it's 4K@120Hz.
http://www.tomshardware.com/news/dell-infinityedge-oled-monitors,30854.html
Tom's seems to be confirming it's running through the Type C connector with Thunderbolt 3.
Even with a 120Hz input, if it doesn't have gaming-oriented features like Adaptive-Sync or G-Sync, and black frame insertion options, it doesn't seem like it would be worth the premium price.
Totally depends on how much you value true black levels. Personally, I would rather have true blacks in most RPGs, strategy games, etc than gsync. For fpses I would rather have gsync.
Fortunately, you're totally allowed to have multiple monitors on your desk
