Dell U3415W Dual Monitor Options!?
Discussion in 'Displays' started by Pregonation, Oct 21, 2015.
  1. Pregonation
    Pregonation n00b
    2
    Mar 1, 2015
    Hi All,
    I've had my 34" U3415W for a while now, and while I love it, I miss having a second screen.
    What are some logical choices for a second monitor? It seems there's tons of sales for this thing lately, but it would be silly to put them side-by-side!
    Would a 16:10 to the right or left make sense, or perhaps stacking them?
    Any advice or input would be appreciated!
    It seems I can't find many pictures on the internet at all regarding two of these, so hopefully someone can provide input.
    Thanks!
  2. tacos4me
    tacos4me Gawd
    774
    Apr 5, 2006
    i ended up with two U3415W (damn those dell deals). i couldn't come up with a setup i liked, it's just way too wide for me. i didn't try stacking them, that didn't really appeal to me either. ended up taking one to work. i use 2x 2007WFP i had laying around in portrait on both sides (angled inwards) of my single U3415W. not the newest monitors, but it works great for productivity mode.
  3. BIGGRIMTIM
    BIGGRIMTIM Gawd
    877
    Jan 10, 2008
    Here is what I settled on.
    [​IMG]
    Good luck.
  4. Pregonation
    Pregonation n00b
    2
    Mar 1, 2015
    Sweet set-up!
  5. jcvjcvjcvjcv
    jcvjcvjcvjcv Gawd
    703
    Sep 28, 2007
    The sadness of 16:9 dominance; need to flip a screen to get decent vertical space, but then stuck with very little horizontal space. At least x1440 tends to be enough for some things.
    I myself have 2560x1600 with two 2007FP's on the side; perfect match for pixelsize. But they (or an update) can't be bought new anymore.
  6. Zepher
    Zepher [H]ipster Replacement
    16,891
    Sep 29, 2001
    do you use the browser in full screen?
    some websites, like facebook, have a lot of wasted space when you have it full screen,
    [​IMG]
    I normally have it like this so it seems like I have 2 screens,
    [​IMG]
  7. geok1ng
    geok1ng 2[H]4U
    2,132
    Oct 28, 2007
  8. jcvjcvjcvjcv
    jcvjcvjcvjcv Gawd
    703
    Sep 28, 2007
    Euh no, that's 10% off. 1440x900 on 17" is 100 DPI, the 34" 3440x1440 screens are 110 DPI.
    Or pixelpitch of 0,255 mm for these 17" and 0,232 mm for the 34".
    Plus they can't be bought new.
    Facebook is a waste regardless of screen :)
  9. geok1ng
    geok1ng 2[H]4U
    2,132
    Oct 28, 2007
    a 17" 1440x900 costs ~$59 refurbished. So 10% off is good enough value, until one finds a 15.5" 1440x900 to replicate the PPI and resolution of the U3415w.
  10. Xinmosni
    Xinmosni [H]ard|Gawd
    1,974
    Mar 12, 2012
    The most logical choice for a second monitor would be a 27" 2560x1440 monitor, as it's almost exactly the same height. Even better if you can find one with a similar bezel and if you can use a hardware calibrator to get it matching the 34"
  11. Saturn_V
    Saturn_V [H]ard|Gawd
    1,598
    Sep 24, 2008
    I used to run a 23" in portrait on the right.
    [​IMG]
    But since it didn't scale well with the 34" so I've basically abandoned it. Took a while to get used to, I've been running dual monitor for at least 15 years.
