Long story short - which one do you think is better for games?
(Of course, I read the threads about both models but I would like to compare exactly those two)
Thank you -)
Are the dark scenes that bad? And is gamma shift on top and the bottom differ too much when viewed from different angles...S27A950D if you only play fast first person shooters that take place in bright settings (no Doom 3, Deus Ex or anything with dark scenes, will not work with that screen).
Dell U2412M for all genres except for old school CS
I had a chance to test the u2412m rev.a03 yesterday and it was incomparably faster and almost ghosting-free in comparison with my present pva monitor. I had dell before but it was rev. a00 and there was alot more of lag and ghosting on it.Depends on many factors. Can your rig push out a steady 90fps constantly on the games you want to play? What sorts of games are we talking about?
In theory the motion on the samsung should be better, as it can refresh twice as often, it also should be a more responsive panel as TN panels are faster than IPS panels when it comes to refresh rate, but AFAIK both screens have very low input lag.
Also, how sensitive you are personally to motion blur also plays a roll, I am not bothered gaming on my NEC screen at 60Hz, some people flat out refuse to game on anything less than a CRT with at least 100Hz refresh rate and basically 0ms response time.
Yes,Ericone, I've got it covered the returns. Actually I expect the screen to arrive tomorrow or on tuesday, and I've already arranged the possible return with the retailer.
Really interesting to see what's so special in that tn panel. I want 120hz for my battlefield, but if it sucks ( and it should), I ll get the dell and be happy I guess. Still, curious to know what others think about those displays, though.
The hp you mentionned is IPS 27" - they all currently suck for gaming. ))
I decided not to try the samsung since it is obviuolsy not for me. I kinda overlooked that it is so reflcetive. I'm sitting in a bright room and I dont usually game in complete darkness, if I play games in the evening or night I turn on the lights or the table lamp. I had the Asus 120hz monitor which is glossy and it was a pein for me for I had to see myself in reflection all the time. I mean I am beautiful, and I like to look at myself but sometimes I simply want to read the internets... So I'll pass on the samsung I guess.
Yes, it takes several hours for it to warm up completely. There is a trick - disable the power save function, then you may turn it on while the computer isn't running and it will be warming up. By the time you turn on the pc, it will be already warmed up.
You should look into the dell u2412m. It is even better for games. -)
As to me, I am going through my second replacement of the dell u2412m. The first one started flicker after I played some battlefiled on it. And the second one showed one dead(or stuck) pixel after I played some battlefield. -) Looks like bf3 kills monitors
Well I was comparing those two monitors yesterday, and today I broght the dell back to the shop for replacemnet, which will arrive only next week unfortunately. So, here what I can say about those displays:
In short, for gaming dell is better for sure. For grapcics work - foris is a steal. I think for the graphics quality it has, it should cost at least twice as much as it costs now. I mean, the average 0.8dE deviation in all colors without profiling (just adjusting RGB gain for 6500K) speaks volumes...
For dark games, dell is better - it shows more details in very dark spots, it is more responsive, has much less ghosting. And in some cases (depending on the colors displayed) I can see absolutely no ghosting at all. It looks very oversaturated in comparison to eizo though, but there that goodness called saturation control in the monitor menu so that is not a problem. Actually the normal state of the Dell is the normal state of the eizo +8 saturation. If you increase the saturation on foris by 8 points the image on both monitors will be almost identical. (note - I compare Game mode on dell vs User mode on foris)
On dell the black is black as much as on foris + some ips glow. Personally Im not bothered by it at all.
For eyes strein - sure nothing compares to foris. But I like bright image, so dell suits me better.
Also on foris the image is crisper, every small detail is drawn and easily visible. But that is so on every eizo monitor... -) And is the main difference between eizo and the rest of the displays.
