Should be U2311H changed to another one if there is a backlight bleed?
How bad is it? Is it really distracting? Is it backlight bleed or IPS glow? If so (distracting backlight bleed) then exchange. However, be aware you could get another with worse problems or a refurbished.
Is there a deal on it somewhere for $200 atm? Or just get lucky?![]()
Anyone used this for color calibration using i1 display 2?
Does the monitor green tinted?
Are you sure that's not your graphics card overriding the scaling or the game itself? Check your settings in the Nvidia control panel.I have a question, though. Is it possible to stretch lower resolutions to fit the whole screen? More specifically, those resolutions that the monitor supports by default? I was trying to play Diablo 2 the other day and it put the game into a very small box in the center of the screen.
I think by default, any resolution game (4:3, 16:9 or otherwise) should fill the screen to the shortest edge, be it vertical or horizontal. The U2311H doesn't have a built in scaler for 1:1 pixel mapping, unlike the U2410.
One thing you may want to try, presuming you're only playing Diablo II single player (you'll get banned if playing multiplayer) and on 1.12, is this resolution hack that should allow you to use your Dell's native resolution.
am i the only one ?
http://www.youtube.com/watch?v=1HI5bazK7FE#
the menu locked by itself, after unlocking it (by holding the first menu button), it gets laggy, and then stop responding..(the power button as well)
Usually it fixed after few minutes..
ok I felt this might help some make a decision <snip>
Anyone hear a very very faint buzzing sound from their monitor?
I bought a NIB U2211H from Dell on eBay. There seems to be a very very faint buzzing sound whenever the monitor is on and displaying a picture.
It looks flawless. Your camera is too close to get an accurate depiction of any backlight bleed because of the IPS glow.
If you are getting an IPS monitor, mainly for gaming, go for the U2311. Its a 1920X1080 more suited for PS3 and 360 and Blu-Ray viewing. Plus its cheaper(much) than its big brother.
I have both, and game mainly on the 2311 for PS3 and 360 and on the 2410 for PC games.
Well, I'm doing only pc gaming on the desktop monitor. How do you like the 2410 vs the 2311? I'm actually debating between these two exact monitors.
Is the 1200 res. noticably bigger? How do the screens compare? I'm wait for the 2311 to show up around $200 and the 2410 for $450.
is there anyway to fix it?? reset the display somehow??
got a pair from the ebay dell deal. $450 out the door. I love the monitors. Considering mounting the one on the right vertically for optimal web browsing and such.
More like optimal fapping, j/k.
I was thinking about getting another, do you use an ARM or something to orient the screens like that? Can't really tell from the picture.
