Dell Optiplex 9020 AIO - Powers up but Black display
Discussion in 'General Hardware' started by qwertyaas, Aug 7, 2018.
  1. qwertyaas
    qwertyaas Gawd
    702
    Jun 25, 2007
    Powering on the Optiplex 9020 AIO, the display remains black. No splash screen, no BIOS, not even a screen flash
    • Tested PSU and works
    • Tested display with Dell built in test and display works and shows all colors
    • Fans all spin up and remain spinning
    • Power button remains solid white while turned on
    • Removing Ram - system goes through the beep error codes
    • Reseated Ram
    • Tried external monitor and nothing
    • Did a GPU reflow on the chip with a heat-gun but did not have an IR thermometer on me - went gradually to 210C and held that temp around 3-4Inch away for 20 seconds and then gradually back down
    Took apart the AIO and checked all connections and all looks plugged in.
    Any ideas?
  2. defaultluser
    defaultluser I B Smart
    12,026
    Jan 14, 2006
    Toss it in the trash bin and buy another like you're supposed to?
    That's what thees things are built for. You've already done more troubleshooting than an over-the-phone tech would have done before giving up and sending you a refurb replacement.
  3. qwertyaas
    qwertyaas Gawd
    702
    Jun 25, 2007
    Where's the fun in that? :)
    But at this point, guess it's time to salvage whatever is in there and toss the rest.
  4. GiGaBiTe
    GiGaBiTe Gawd
    651
    Apr 26, 2013
    +1 for defaultuser's suggestion of tossing it in the trash.
    If it wasn't totally dead before you got the genius idea to fry the machine with a heat gun, it is now.
    Heat gunning a board is not reflowing, especially if no flux is used.
  5. qwertyaas
    qwertyaas Gawd
    702
    Jun 25, 2007
    Heat gunning GPUs on a board worked in the past. I never used flux when doing that on a GPU either - it revived quite a few cards.
    But anyway, tossing it. Nothing lost other than a some time.
  6. GiGaBiTe
    GiGaBiTe Gawd
    651
    Apr 26, 2013
    It doesn't work, it's just a temporary fix. The solder gets tacky enough to make a weak connection, but any tiny amount of thermal stress will cause it to fail again.
    At best it lasts a year or two, a worst, a few weeks or months.
    ROHS solder is junk.
    pendragon1 likes this.
  7. Gordo74
    Gordo74 Gawd
    817
    Mar 1, 2011
    Really dumb suggestion - Plug in a USB keyboard. My Optiplex 9010 exhibits the same behavior without one.
  8. qwertyaas
    qwertyaas Gawd
    702
    Jun 25, 2007
    Yeah tried that first.
    It was just needed for temporary fix anyway. But it didn't work so in the trash it went. My GTX460 lasted well over two years after I baked it, but at that point it was time to upgrade that GPU anyway.
