CaptNumbNutz
- Apr 11, 2007
I was recently gifted this snail.
Atom N470 Single core w/ hyper threading
1GB of DDR2 RAM
5400rpm 160GB WD drive.
Non-touchscreen version.
Full Spec sheet from Dell.
I maxed it out with the junk I had laying around. It now has 2GB of RAM (maxed) and a 240GB Crucial M500 SSD in it. I also replaced the ancient broadcom 802.11G wifi with some Azure 802.11N unit that I pulled from a dead Asus ultrabook that I was sure had updated drivers.
It came with Win7 Basic 32bit edition. I did a fresh install of Win10 Pro 64bit using the Win7 key. Win10 found every driver it needed except the drop sensor which I don't need anyways since I'm using an SSD now. The CPU is 64bit capable, but obviously can't manage any decent amount of RAM.
I've installed Spybot Anti-Beacon to alleviate some of the Win10 bullshit to possibly use less system resources.
Is there any benefit to using the same hardware but dropping it back down to Win7? If so, should I use Win7 32 or Win7 64?
I do not wish to discuss Win10 "spyware" unless it has to do with overall system performance. I'm fully aware of what Win10 shares with MS.
If it helps, here is what I want to accomplish with it:
-Basic Websurfing
-Basic SD streaming video
-Really old games (pre-2001), possibly NES emulation
It's a neat little toy, and I would like to keep it. The exterior is rubberized, its got the extended battery and goes for days in sleep mode.
Now a few of you are probably thinking drop Linux on it and forgo windows. I would like to dual boot Linux on it at some point to learn. I do not expect to do much application wise with Linux. I do have to have Windows as I'm not a Linux guru yet. Therefore I need the following answered:
-What windows should I run? Win7 32 basic, Win7 64, or Win10 (with a bunch of bells and whistles disabled). I have Win 8.1, but unless someone convinces me otherwise I doubt it would be a good fit.
-What flavor of Linux should I run? Please consider the hardware and something relatively noob friendly. Ubuntu was the recommended when this thing first released, but that may not be the case now and I am way out of touch with Linux.
1GB of DDR2 RAM
-Basic Websurfing
