dell h200 reporting as int tape adapter
yee379
Hi, i purchased a h200 off ebay and it reports as 'int tape adapter'. is this the same as the standard dell 6gbpsSAS? is there any chance of bricking it if put the 'standard' Dell 6Gbps SAS HBA firmware IT firmware on it?
mwroobel
Chances are you are in IR mode, I have seen that card ident that way. If you are at Dell IR right now, you have to go to Dell IT first, then to LSI IT. For flashing info to set it to IT, see here.
