Dell 9300 2.13ghz processor running at only .80ghz HELP!
Discussion in 'Mobile Computing' started by doug_7506, Nov 1, 2005.
  1. doug_7506
    doug_7506 2[H]4U
    3,159
    Oct 17, 2004
    Well just as the title says my 2.13ghz laptop is only running at .80ghz in age of empires 3. is there some kind of setting someplace that shows you how to adjust tis. it says on the pop up whne i put the game on that my processor was not running fast enough. it sais it may be due to running on battery power whihc im not, im running on the wall power.
    thanks
    doug
  2. MinistrOfJustiz
    MinistrOfJustiz Limp Gawd
    147
    Jul 27, 2005
    you got your XP power settings on "max battery" or something?
  3. lithium726
    lithium726 [H]ardForum Junkie
    8,199
    Jun 16, 2004
    even with max battery set, my CPU ramps up when its plugged in..
  4. doug_7506
    doug_7506 2[H]4U
    3,159
    Oct 17, 2004
    how do yall turn up the power to the machine?
  5. Foz2001
    Foz2001 [H]ard|Gawd
    2,032
    Aug 25, 2001
    is this just in age of empires? Go to system info and see what speed its running at.
  6. lithium726
    8,199
    Jun 16, 2004
    what are you using to monitor CPU speed? the windows clockspeed report wont change when the CPU does, use something like CPUZ
  7. UltimaParadox
    UltimaParadox [H]ardness Supreme
    6,247
    Mar 8, 2003
    This is due to the fact that when you are installing the game it reads the processor speed, and since SpeedStep is enabled to protect battery life etc it is currently only running at 800mhz when the proc is pegged for what speed it is. I would ignore this as it just means speedstep is working correctly. I bet if you monitored your CPU speed while playing the game, that it will be pegging at the correct 2.13ghz.
  8. MaxHardcore
    MaxHardcore Gawd
    978
    Mar 14, 2000
    There is always "Notebook Hardware Control", formerly know as Centrino hardware control.
    google it.
