Dell 27" 5K Monitor (5120x2880)
Discussion in 'Displays' started by 4KTVBlog, Sep 4, 2014.
  1. x3sphere
    x3sphere 2[H]4U
    2,628
    Dec 8, 2007
  2. cerilia
    cerilia Limp Gawd
    239
    Dec 31, 2004
  3. Vega
    Vega [H]ardness Supreme
    6,259
    Oct 12, 2004
  4. WorldExclusive
    WorldExclusive [H]ardForum Junkie
    10,867
    Apr 26, 2009
    Sub $1500 I would consider it, if it were SST.
    We just have to wait until DP1.3 becomes standard.
  5. turbineseaplane
    turbineseaplane Limp Gawd
    204
    May 6, 2014
    Yeah. Too pricey for now. And the dual DP stuff sucks also. Agree.
  6. Vega
    6,259
    Oct 12, 2004
    Unfortunately, timelines for DP 1.3 GPU's and DP 1.3 TCon's for displays is still quite up in the air.
  7. wirk
    wirk Gawd
    811
    Sep 2, 2014
    This is very true, it is not evident the next Spring crop of GPU's and monitors will have DP1.3.
  8. ckeck
    ckeck n00b
    33
    Jan 3, 2013
    I have a small batch of these coming in this week and I'll be posting for sale on Amazon < $2,000. Message me if interested. Can look at a slight discount if you'd like to buy one direct since there won't be any Amazon seller fees.
  9. initiald
    initiald n00b
    1
    Dec 15, 2014
    Hi guys, just received my unit yesterday. :) Very happy and exited at the same time. The WOW feeling of seeing windows display such crisp text was very much the same as 20 years ago when I got my Diamond Pro CRT.
    Currently at 4k resolution because there's only 1 display port on my Asus R7 250 on my lowly Q6600 Socket 775 board. I don't play games. Once my Firepro comes, I'll hit 5k.
  10. turbineseaplane
    204
    May 6, 2014
    I hope they make a version in the 31-34" range.
    To me that's the perfect physical size to go along with 1440p perfect 2x scaling of 5k resolutions.
  11. cerilia
    cerilia Limp Gawd
    239
    Dec 31, 2004
  12. dpoverlord
    dpoverlord [H]ard|Gawd
    1,709
    Nov 18, 2004
  13. Vega
    6,259
    Oct 12, 2004
    11ms if accurate is pretty dark good. Less than one frame.
  14. datap1mp
    datap1mp Limp Gawd
    138
    Feb 23, 2006
    I really wish this was at least 30" :(
  15. cbf123
    cbf123 n00b
    50
    Dec 12, 2013
    Those tests are not very helpful. Would have been better to have a comparison of the same monitor before/after painting the bezel.
    Personally I think that glossy monitors have the best perceived black levels where there are no visible reflections, but that it's almost impossible to avoid reflections in them.
    Matte monitors don't look as good under the best-case conditions, but under typical office conditions will look better due to the reflections being diffused.
    The ideal would probably be a glossy monitor with lab-grade anti-reflection coatings. But that would get expensive.
  16. Despotes
    Despotes Gawd
    787
    Aug 27, 2005
    27" 5K? Are we sitting 3 inches away? :rolleyes:
    Ridiculous.
  17. Quartz-1
    Quartz-1 [H]ardness Supreme
    4,257
    May 20, 2011
    How close do you hold a printed letter when you read it? That will be at least 300 dpi, likely 600 dpi.
    You are used to 75-100 dpi on monitors. Higher dpi is a qualitative improvement. Gamers are not the intended audience.
  18. Despotes
    Despotes Gawd
    787
    Aug 27, 2005
    Even for photo a 32" or 34" would be much better than a relatively small 27".
    Reading text is out of the question.
  19. cerilia
    cerilia Limp Gawd
    239
    Dec 31, 2004
    This display has comparable DPI to my 15" MBPr on which text looks awesome.
  20. jblue42
    jblue42 Limp Gawd
    497
    Jan 18, 2004
    go to an apple store to see 27" 5K in person. Text looks incredible.
    OS X definitely has scaling down, looks great. Windows scaling will catch up eventually.
    The DPI on your phone is significantly higher than your current monitor, and text looks great. Only a matter of scaling..
  21. dpoverlord
    1,709
    Nov 18, 2004
    If this were larger I'd totally be interested
  22. epa
    epa [H]Lite
    66
    Apr 3, 2014
    houkouonchi, I also thought the UP2715K used MST and four logical screens, but in the Nvidia control panel I see it appearing as just two - the same as the UP2414Q. So I'll try connecting another couple of (non-MST) monitors to use up the two remaining logical screens! (I drive it from a Nvidia NVS 510 card, which has four DP1.2 but a four-logical-screen limit.)
  23. Quartz-1
    4,257
    May 20, 2011
    Ah, thanks for that tid-bit.
  24. epa
    epa [H]Lite
    66
    Apr 3, 2014
    OK, good news! The UP2715K appears as two logical screens - not four. This means that it uses up only two of the outputs on a Nvidia card. From one NVS 510 card I am currently driving one UP2715K (at full res and full refresh) plus two T221s with DL-DVI adaptors (at full res but only 24Hz refresh).
  25. Quartz-1
    4,257
    May 20, 2011
    Since you have the monitor to hand, could you possibly try it in portrait mode? I really like the better text I get on my 4K display, but have two monitors in portrait mode.
  26. epa
    epa [H]Lite
    66
    Apr 3, 2014
    Yes, it will rotate to portrait mode. As an IPS panel, the viewing angle is just as good when rotated. But I find the top of the display too high like that. I have two UP2414Qs in portrait mode and even those are a little bit too tall. (Good ergonomics says you should look slightly downwards at the monitor, with its top roughly at eye level. I have a low desk but not low enough to use a 27 inch monitor in portrait orientation without straining my neck.)
  27. jb1
    jb1 Limp Gawd
    495
    Dec 27, 2014
    Just curious, will this monitor take one DP 1.3 input to achieve 5K whenever cards are available that support that? Or, is this monitor locked at requiring two DP 1.2 signals forever?
  28. Quartz-1
    4,257
    May 20, 2011
    Thanks.
    I'm 6'4" and tall in the trunk, so the top lines of content are generally at eye level, with tab titles, menus, etc being slightly above.
  29. Vega
    6,259
    Oct 12, 2004
    There are no DP 1.3 transmission controllers out yet, so new hardware would be required. I'm not even sure if this next GPU release by AMD and NVIDIA will even have DP 1.3.
  30. Quartz-1
    4,257
    May 20, 2011
    Ah, Vega returns! You, of course, have three of these, right? Or do you have five 4K monitors? :)
  31. Martha Stewart
    Martha Stewart Gawd
    605
    Apr 14, 2011
    Anyone here on [H] actually have one of these yet? I would love to get one, but curious if its worth it over 4k.
    If it was 32" I would be in already, but 27" is so damn small when I am used to larger screens:(
  32. jb1
    jb1 Limp Gawd
    495
    Dec 27, 2014
    Darn, that's what I had thought!
    Also agreed that a 32 inch 5K screen would be lovely... I've seen the 27 inch 5K screen on an iMac and yes, it is beautiful. However, worth it over 4K @ 27 inches? Not sure.
  33. DaPayne
    DaPayne Limp Gawd
    180
    Jan 28, 2015
    I have the UP3214Q's and just picked up one of these yesterday. To me the 32" monitors are a bit too much but 24" isn't enough. I did like my 3xU3014's though, so maybe this will work. I haven't had a chance to even pull mine out of the box but will in the next couple of days. Also I did have a 5K iMac for a few days but I really wanted the power of my hackintosh on my main machine.
  34. epa
    epa [H]Lite
    66
    Apr 3, 2014
    I use 200% font scaling, so for me the 24" 4k monitors with 184ppi make the text a little bit too big. The T221 with its 204ppi is okay and the UP2715K at 218ppi is just right.
  35. epa
    epa [H]Lite
    66
    Apr 3, 2014
    I have been using a Dell UP2715K happily with a Nvidia NVS 510 card. It drives the screen at full res (5120x2880) and 60Hz refresh without problems. The card is also able to drive two other monitors at the same time.
    However, I have not been able to set up two of the Dell UP2715K monitors - neither by plugging them both into the same NVS 510 card, nor by having one card for each. The second UP2715K will do 3840x2160 only, despite being connected with two DisplayPort cables.
    Does anyone here have a working setup with two 5k monitors?
  36. epa
    epa [H]Lite
    66
    Apr 3, 2014
    OK, an embarassingly simple solution - only one of the two DisplayPort cables was connected, so only 4k resolution was available. The UP2715K on-screen display shows two DisplayPort icons side by side, but that doesn't necessarily mean that both ports are connected, only that it will try to use both if possible.
    So you can successfully drive two UP2715Ks from a single NVS 510 card. (It also works to have two NVS 510 cards in the same machine and drive one UP2715K from each. Which means I expect that driving three or four of these monitors would work with a pair of NVS 510 cards.)
  37. runffs
    runffs n00b
    53
    Jan 27, 2009
    Is there any way to run and SLI or tri LI configuration with these monitors?
  38. Quartz-1
    4,257
    May 20, 2011
    Yes. See this thread.
  39. Vega
    6,259
    Oct 12, 2004
    Disregard.
