The Gateway, BenQ, and Dell A03 are all PVA panels. There was a rumor about the Dell A04 being lottery IPS because a Dell Tech posted a revision roadmap, but it looks like there's a higher chance A04 is going to be a TN rather than IPS with the rumored 2407-HC (read: really bright TN).
hi guys, I just got my replacement from dell and it's an ao4 revision, only thing is I still don't have access to the 1:1 option in the menu
what inputs you are using ? there should be 1:1 on DVI atleast...
thats what I'm using, DVI, strange, I've checked the back, it's defo ao4, when I go to the display settings I won't let me change the 'wide mode' options which are 1:1, Aspect and Fill
lowrider,I am not having this problem.I use dvi instead of vga.Good luck.Are you in the regular menu? or the service menu ?
Or are you talking about display properties in windows ? If so what card ? ATI or Nvidia?
Here's a pic of the options that are grey out, on the back of the Monitor it has a sticker that reads REV A04 and a barcode with the serial number above it, it also says it's rev AO4 on the box.
At what resolution? Because if you are at full panel resolution 1920x1200. There is nothing to fill/aspect/1:1.
You need to feed it a lower resolution and see what happens. You also then have to make sure you card isn't filling in the black bars for you. Nvidia cards do this, ATI don't.
I've just tested a few games out at different lower resolutions and still the option was greyed out, I am using a 8800gtx if that helps, do I need to change any settings in the nvidia control panel ?
SO Since the Dell 2407WFP since the 2407 is in revision 04 can
a person request they get the 04 revision upon ordering? As well
Is this a TN monitor or s-pif monitor? im abit confused on this area.
Would a BFG 6600 GT OC handle this size of monitor?
Thanks.
There are options in the Nvidia drivers to have the video card deal with the pixel mapping (e.g. center, aspect mode, etc). If you select to have the video card do this instead of the monitor, the video card is padding the resolution to the full 1920 by 1200 -- so, for instance, if you set the resolution to 1600 by 1200 and have the video card center the image, the video card adds the extra 160 black columns on each side of the image before sending it to the monitor. So, from the monitor's point of view, it's receiving a full 1920 by 1200 image, and the pixel mapping options should be grayed out.I've just tested a few games out at different lower resolutions and still the option was greyed out, I am using a 8800gtx if that helps, do I need to change any settings in the nvidia control panel ?
I don't remember where the options are specifically (I'm on my laptop at the moment which has integrated graphics), but there should be an option to let the monitor handle the scaling instead of the video card. If you are able to find this, then I'd assume the Dell options wouldn't be grayed out. I'll try and see if I can find it next time I'm on my desktop.
So even if you do manage to get your hands on an A04, you still aren't guaranteed 1:1 mode in all resolutions?To access the 1:1 pixel mapping, the firmware needs to be the latest version. This USUALLY coincides with the monitor revision A04, but may not. For example, a firmware update was done between the A00 and the A01 revisions. Hopefully the 1:1 mapping was updated on your A04
I think we need more A04 people to come forward and tell us if, indeed, 1:1 mapping is activated. I am still waiting to order my 2407 until I get confirmation that A04s have 1:1 mapping consistently. I'm aiming for the first week in March, but I need SEVERAL confirmations that A04s are doing this.
If March comes and the Dell still is hit and miss, I'll go to the gateway 24" instead. It's rather ridiculous waiting this long for these updates to show up and do what they should be doing.
According to the above poster, it is there.So even if you do manage to get your hands on an A04, you still aren't guaranteed 1:1 mode in all resolutions?
Dell REALLY dropped the ball this time.
But, it makes me ask: If your video card can do the 1:1, then how important is it with the A04?
Maybe for connecting external devices directly to the Dell 2407WFP, such as X-Box, home DVD player, etc.?
Yes, no?
Just to let you know, the ability on some Nvidia cards to switch the pixel mapping control back to the monitor is broken at the moment. At least on the 8800's from EVGA. I have the 8800 GTS with an A03 2407 and right now the problem is you can go in and make the change, apply it even. But it doesn't retain the change. If i close the window and reopen it it reverts back to the default setting. Hopefully they fix it soon. But it works just fine in allowing me to adjust using the VGA input instead, which im using as a workaround until they get it all fixed since the card has two connections.
Was hoping I'd get an A04 since i got mine just last week, but I'm being optimistic that more and more games will be designed with resolutions that take advantage of widescreen monitors and i wont have to fret as much over the 1600x1200 problem, or just run it at 1280x1024 and deal with a little fuzzier image. Ive had monitors alot worse than this so for me I can deal with it giving me 95% of what I want.
yes I agree, if your going to be plugging a 360/PS3 etc into it then it could be important to have 1:1 pixel mapping but if your just using it for the PC and your gpu can do 1:1 pixel mapping then I really don't see a need to upgrade to the ao4 revision, tbh I never even knew you could even change the scaling options in the nvidia panel.
I've just reading about this in nvidia's forums, they have a thread on it here, http://forums.nvidia.com/index.php?showtopic=23064 , this is the reason why I thought the 1:1 pixel mapping was'nt working properly on my ao4 revision because it won't let me select "Use my display's built-in scaling" option, I just tried my latop on it and it works fine to it's definitly an issue with the drivers and not the screen, nvidia are being a real pain in the arse atm with thier driver releases.
You're one of the few users I've seen to have the HN213 panel. Care to do some screen uniformity test? Like the ones on this page - http://www.hardforum.com/showthread.php?t=1111100&page=5i just got an A03 made in mexico, HN213 panel shipped out of Texas, ordered it last friday. in case anyone cares lol
I'm kinda interested to know what is the actual panel being used with the HN213 code.
Yeah. Try taking angled shots of this image as shown in this page.tell me what u want and i'll try to do it when i get home from class today. just the angled pics like in that link??
Snowdog said:Look at this image. On a S-IPS screen this will have consistent shadow detail across the screen, PVA will vary across the screen:
http://ct.pbase.com/o4/04/606404/1/5...1920Shadow.jpg
Something like this from different locations on the screen on my PVA I sent back:
http://ct.pbase.com/g2/04/606404/2/6...8.x4iiT08h.jpg
There are two panels being used in the A04, namely HN208L and HN213. I'm not sure what these panels are though, but the 2407 has been using Samsung's S-PVA panels all along.bty just out of intrest what panels are these ao4 revisions using ? PVA ?
Hmm, maybe that's because the 2405 used PVA rather than S-PVAs?If both those shots are at the same exposure, then it is definitely PVA.
The behavior of PVA is that washout you see in the angled photo. Where everything darker turns lighter and loses a lot of contrast.
On the head on shot it looks a bit better than typical PVA (Better than my 2405 did). I see a slight darkening in the center with slight washout on the sides. This was more obvious on my panel.
I doubt this is IPS, but it may be a better PVA than I had.
There were no 2407 IPS panels before Dell hid the panel names in code, and I suspect there still isn't.
Take it apart and find out for us.
I doubt its an IPS panel too, but it does look better than those posted in the lottery threads.i agree, its probably not an s-ips panel. but i think the photos are exagerrated because of the light in my room because what the camera picks up is not what my eye sees. when i angle the panel i see very little washout compared to what the pictures are showing. i'll try to do some tonite.
FarmerJohn said:When I view a dark photo straight on, it is mostly black, but when I move to the left or right, the photo is more visible - more detail. Is this what 3d shift is? In this photo, I can't see the pipes at the top when viewed directly, but are clear when viewed on an angle. Does this confirm I have a PVA panel?
That probably concludes the fact that the HN213 is indeed a S-PVA panel too, as with the HN208, but why two different panel codes?yeah, now that makes the washout more pronounced. especially the top of the upper set of pipes, they become more visible when turning the monitor. still, it's not bad at all
