im thinking this is what you meant...TehQuick said:...Visit widescreengaming.com and see for urself...
according to the thread i posted above there is no field of view fix yet, bummer.TehQuick said:change FOV, and it'll be all better
right on Kevlarman. so how do i switch to these modes?Kevlarman said:With the 2405FPW you have three choices for running a non-native resolution:...
jwill said:so how do i switch to these modes?
first thing i did. the image scaling option is grayed out, wonder if its because of the dvi connection.saiyan said:Have you checked the OSD controls of your LCD monitor?
You can change the image scaling option there.
hmm... youd think so. im not seeing the option anywhere in the advanced display settings.GLSauron said:turn off scaling in the drivers. And set resolution at 1600x1200. Should be easy.
