BobbyD said:I haven't tried it so I don't know if it will work or not, but a professor of mine said it would work. He's a EE professor so I assume he knows what he's talking about.
If you have an electric pencil sharpener you could hold it a few inches in front of the TV, start it up by jamming a pencil in it, and then slowly pull it back from the TV. The varying magnetic field of the sharpener should act similarly to that of a degaussing coil.
m1abram said:A simple and safe method is, grab a monitor that has a degauss feature. Place it with the tube as close to the TV tube as you can. Press the degauss, you may need to do it a few times.
kleptophobiac said:uhhh.....?
