I had purchased an Intel X-25 G2 160GB a few days ago, and had the opportunity to update the firmware and install Windows 7 on it.. unfortunately it would not allow me to do so. Regardless of trying AHCI or IDE, as well as having both other hard drives unplugged and plugged in during the install, (74GB Raptor and 500GB Seagate), I would continuously receive the following error:
"Windows cannot install required files. Make sure all files required for installation are available, and restart the installation" (Error Code: 0x8007045D)
Thinking it may be a problem with the DVD itself, I tried installing Vista as I knew that DVD is fine, but I received the same error. CrystalDiskInfo shows nothing wrong with the drive, and the SMART report on the Intel Toolbox shows everything being fine. The drive however does NOT pass the Read Scan test in the Intel Toolbox (fails within 10 seconds), and I've noticed when copying files to the drive it is abysmally slow, as well as deletion of files.
I tried running HDDerase to secure erase the drive, but this did not help unfortunately. Anyone have any ideas, or is this drive effectively just a defective one?
