That sucks.I got one, sucks i got dead pixels, doing exchange/return. takes forevever
That sucks.
But I think you’ll like it. If you have any questions I’ll be glad to help if I can.
The only issue I had was Windows Update kept breaking the Radeon control panel which I used to increase the brightness and contrast to eye bleed levels when I played the earth bound levels of Black Mesa.
Since it’s running home and not professional you can’t policy edit your way out of it and the registry edits didn’t fix it.
Ended up using the Microwsoft Show Hide tool wushowhide to block the 3 AMD drivers that windows update would install after I would manually update the Radeon driver.
don’t forget to flash the latest bios, since this thread was started they released two, a MUX and a better temp management/fan curve
Speaking of fans, I don’t find them noisy even when the G button is pushed.
Awesome.They are building my replacement
Replacing it with a Special Edition Model
Hi I brought this laptop last week got it for a great deal paid £800 for it new. Ryzen 7 5800 and the RTX 3060 GPU 16gb Ram and ive added a 1TB SSD. this is the first gaming laptop ive owned and ive seen some posts here about things to do with it. The only thing im let down by is the display 120hz and 28ms response is slow also colours look quite dull. I was considering buying the 165hz panel from Dell that the sell in other models of the G15 would this work. or does anyone have any work arounds to improve the displayYou wont be disappointed performance wise. the 5800H is a beast! Main thing these days with AMD based laptops and Nvidia GPUs
Single channel vs Dual Channel memory config
TDP watt spec for the GPU and in the 30XX line this can vary greatly
For this model is screen quality and cooling is what I would make sure is solid.
