Dead 5820k New 2600 build
jmnovak
So my X99 system took a dump. No post, code 00. wasnt going to vest in aging system so went with a 2600 for now. Wanted to make sure voltage and temps seemed within range since its been a while since I was on AMD platform.
Specs are in sig.
4.2ghz @ 1.36v
Lvl 4 LLC
Prime95 26.6 Blend- 4hrs max temp 71c
avg. 1.403v
max 1.450v
Aida64 stress test- 5hrs max temp 73c
avg. 1.401v
max 1.428v
Real Bench stress test- 5hrs max temp 62c
avg. 1.394v
max 1.406v
Gaming was giving me about 1.373-1.384v avg depending on game
Wasnt sure if those voltages are 24/7 safe?
Just try to stay below 1.45 volts for extended periods and you will be fine. Your temps look good as well.
Yeah that all looks great. Basically the same thing happened to me, random 00’s with my 5960x. Jumped to AMD and never looked back.
Thanks guys. Overall pretty happy. System performs close to my old 5820k @ 4.7ghz
5820k@ 4.7
CB11.5-
single core 2.10
multi core 15.40
CB15-
single core 188
multi core 1421
CPUZ
single core 501
multi core 3740
2600@ 4.2
CB11.5-
single core 1.95
multi core 15.65
CB15-
single core 176
multi core 1441
CPUZ
single core 499.5
multi core 4008
under load
idle voltage of 1.45 is fine all day and night because there is no current being pulled, thus no additional heat.
Yeah/ Ive been playing around with settings. CPU can pull 4.325ghz but takes 1.42v in Bios and under load its 1.502v Temps get up to 81c. Way to much temp and voltage increase for 125mhz so I backed it down to where I was.
As far a memory.... Im stuck. No matter what I do it wont go past preset D.O.C.P of 2666 13-14-14-39-1T,(Board defaults CAS to 14 even when set to 13) even if I loosen timings. (The chips are older Hynix) Which is crazy because I had it running @ 3200 14-15-15-36-1T 1.40v with the X99 system
I'll have to invest in some Samsung B-die 3200 or 3600.
Update: Was able to set DOCP to 2400(13-13-13-35-1T) then up speed to 2666. But system doesnt like
Anything lower than (14-13-13-35-1T)
Ya that is an issue with Ryzen. Memory is difficult. Newer modules are better at timings and hitting rated speeds.
Yea... after messing around with the system I was able to get everything stable(prime95/RealBench 8hr runs) @ 4.225ghz 1.381v w/LLC5 and Mem.2866mhz 14-14-14-39-1T using Dram Ryzen calculator.
No matter what setting I used memory wouldnt go any higher than 2866 stable. I am using 4 dimms and have read that it effects speeds/timings.
CB15 pulls 175/1445
Ya 4 sticks limit the available bandwidth to the memory controller. its always better to buy two sticks of the highest capacity that you can afford. Ryzen loves the higher clocked ram, but also likes lower timings. So its kind of a balancing act. Get the setting right and you should have a monster of a rig.
Here what Im getting memory wise
I got a 2600x a few weeks ago and used 16gb of 3200mhz ddr4 that was in my 6600k system (older samsung ram, not b-die). I can't get any better then 2800mhz stable (16-16-16-36) I can boot into windows 10 at 2866/2933 but system will lockup quickly.
Even tried with super loose timing but no success there (with ryzen dram calc). My board will also boot at 16 cas if I set it to 15.
I'll probably run those for a while and eventually get a better set. I've seen many report of 3400 to 3700mhz ram working flawlessly and I kinda want some of that!
Still waiting on my AIO bracket adapter so I'm using the stock cooler for now and haven't messed with it so far since it goes to 4.25ghz with PBO and temps creeps up higher then I'd like (85c+ and still climbing) while stability testing.
Cpuz is reporting 1.344vcore under prime95 at 4.0ghz with pbo and from my research below 1.4v should be safe.
Out of the box with stock cooler the 2600x is pretty impressive. Can't wait to put my h220 on it and see what it'll do!
Yeah... 4.225-4.25ghz(1.381-1.410v) seems to be doable limit. I pushed 4.35ghz but it took 1.52v to get stable which was crazy for 100-125mhz more. but very happy with platform so far. Get some 3200-3600mhz B-die and call it good till the 3600+ chips come out.
