Nenu
[H]ardened
- Apr 28, 2007
A year ago I bought a Z170 system with 4x4GB Corsair Vengeance LPX 3000 C15. Kit name: CMK16GX4M4B3000C15
In my first mobo, MSI Z170a Gaming Pro, it barely ran at default 3000MHz speed.
A later ASRock Z170 Extreme 4+ had similar problems.
On both boards with certain BIOS versions I could use it for gaming at rated speed but it failed testing.
Anything that needed the CPU at full pelt I had to slow it down to 2800MHz for stability.
Other BIOS versions knocked it down to 2500MHz max.
Manual settings got it rock stable at 2800MHz with certain BIOS versions, nothing faster.
I got an RMA from Corsair but didnt take them up on it.
They offered to replace the 4x4GB with the equivalent 2x8GB.
I eventually got an Asus Maximus VIII Hero Motherboard and at last was stable at default XMP 3000MHz but it wouldnt clock any higher.
That was in March.
I considered the RMA again today because the memory is advertised as being good for overclocking so decided to try clocking it again.
This has been one of my simplest clocking experiences.
A few times I had to press the mobos get out of jail free button when using too low a timing but it didnt once crash while booting or when in Windows.
This ram which could barely run at default speed before now clocks to 3733MHz in the new board and I can game fine with it. At default 1.35V as well !!
I didnt try hard to get it fully stable at 3733MHz because the timings seemed a bit too high so I backed off to 3600MHz with this final result:
1.35V 3600MHz 19,20,20,42 and tRFC = 480
Thats 20% higher clock speed and slightly higher timings than shop bought 3600MHz ram, result!
Default:
1.35V 3000MHz 15,17,17,35 tRFC less than 300 - forgot to write it down
I decided to see what this would do with my clocked 980ti, 6700K @ 4.6GHz.
Practically jack all lol.
Games, no benefit at all. Password cracking (yeah I forgot one), no benefit.
Windows is a bit snappier and new connections over broadband are made a lot faster. I use Peerblock and the speed which connections whiz up the screen is significantly faster.
Neither was a problem before, so no real advantage.
So there you have it, some crap ram isnt so crap and clocks like a nutter in the right motherboard/bios.
But theres not really much point going beyond 3000MHz.
That was in March.
Default:
