https://pcpartpicker.com/product/Tj...-1-x-16gb-ddr4-3600-memory-f4-3600c19s-16gvrb
So the caveat is that the memory is actually rated as 3600mhz 19-20-20-40. Posted this over in the HotDeals section since figured it was a steal at $130 per 16 gb kit.
Was not able to get the memory stable at the rated 3600mhz speed with DOCP profile on my x470 Asus Crosshair VII Hero (Wi-Fi). So started dropping the frequency and tightening the timings. Got it stable 10 passes of IntelBurnTest on Maximum at 3200mhz 14-15-17-21 /w DRAM Voltage 1.4 and CPU SOC Voltage of 1.1. I'm using two sticks [from separate kits] in dual channel mode on the Asus x470 Crosshair VII Hero.
Save this and reset.
Run 10 passes of IntelBurnTest on Maximum overnight to ensure stability, then drop the timings down and retest until you find the limit the latency can be tightened.
The memory is Hynix CJR, 2 rank, 16gb per kit. Thoughts? Never seen DDR4 with RAS Active of 21. Heck from most kits of Samsung B Die you're looking at upper twenties or low to mid thirties.
Disclaimer
Am not responsible for any overclocking the reader chooses to perform. Overclocking is done at your own risk.
- First set the DOCP Standard profile.
- Second drop the frequency to 3200mhz.
- Third set the DRAM Voltage to 1.4v [XMP 2.0 supposedly goes to 1.5, so 1.4 should be safe but YMMV].
- Fourth set the CPU SOC Voltage to 1.1v [DRAM Calculator recommended the 1.1v at max for this kit].
- Fifth enter the DRAM Control submenu and change the latency to something like 16-18-18-36.
Disclaimer
