ddr2 1066
If you're not overclocking, definitely DDR2-800 (unless somehow DDR2-1066 is cheaper).
The E8400 has a 1333Mhz quad-pumped front-side bus, which means the base bus speed is 1333/4 = 333Mhz, ish. The RAM runs at some multiple of that 333Mhz speed, which is then doubled (because it's Double Data Rate RAM) to get the RAM speed. The lowest multiple of 333Mhz you can get is.. 1x333Mhz, which is doubled to get 666Mhz. Therefore if you're not overclocking, even DDR2-667 would be sufficient for the CPU if it's not overclocked - but RAM is cheap, so you may as well get DDR2-800. RAM with a higher clock speed is not noticeably faster in any real-world situation, so there's no reason to get DDR2-1066.
(Incidentally, DDR2-800 would allow you to overclock up to 800/2 = 400*9 = 3.6Ghz, if you had a good chip and motherboard and decent cooling etc. DDR2-1066 RAM would theoretically allow a maximum of 1066/2 = 533*9 = 4.8Ghz, but that's impossible. The 9 in these calculations is the CPU's clock speed multiplier, which is based on the 'true' bus speed, not the quad-pumped speed.. but don't worry about that.)
Based on the price difference, I'd spend the extra $20 and buy faster, more future-proof memory. As the P5E and my Maximus Formula are basically the same board, these are the sticks that I run my E8400 on. (500*8) http://www.newegg.com/Product/Product.aspx?Item=N82E16820148069
The OP may not have current plans to OC, but if he keeps hanging out here, he may just change his mind. :cool:
With DDR2-800 I hit an insurmountable wall at 450 MHz FSB.
With DDR2-1066 I've run 515 FSB with stability, and I know I can go higher.
maybe one of these days for now just wanted to get the best stock performance possible.
Great post. Very helpful.
Which is better with a Core 2 Duo E6600, DDR2-800 or DDR2-1066? Would the DDR-1066 be perfectly in sync with the Core 2 Duo E6600 1066 FSB?
- Thanks
- Thanks
DDR2-800 is fine for the E8400. At standard clockings, the E8400 runs the memory at DDR2-667, so anything above that is fine.
Hi, what type of memory would be in sync with the FSB of a Core 2 Duo E6600? Thing is I would like to build a system which has no compensation when it comes to cycles between the CPU/Memory.
- Thanks
- Thanks
stock fsb is 1066, or 266mhz.. which is the speed DDR2-533 runs at
though why don't you want compensation? while there is a bit of extra latency in the memory controller when running at ratios other than 1:1, it's not noticeable, and in the end, overall memory access time is what decides things anyway, and faster ram almost always has lower access latency.
that said, the difference between some ddr2-533 and ddr2-800 will definitely be less than 2-3% in real world performance.
wow didnt know that :D thanks what will happen if i dont run 1:1 is that bad? cuz it consume more power and generates more heat? sorry if its a stupid question
thanks
edit
one more question how would ddr3 work? lowest multiple of FSB X 3 ?
same way as ddr1 and ddr2 work... it's just a matter of what the fsb is, and what the memory speed is. the right ratio is selected based on those two to get the proper memory speed.
so if you have a 1333 fsb chip and some ddr3-1600, it's 333mhz fsb with 800mhz ram. the ratio would be 12:5 (DRAM:FSB)
