Dayton Audio 18" Ultimax Subwoofer Driver / GSG Audio DIY MartySub Enclosure Sale - 16Hz!!! Feel It!
Discussion in '[H]ot|DEALS' started by Sabrewulf..., May 8, 2019.
  1. Sabrewulf...
    Sabrewulf... Gawd
    990
    Jan 18, 2008
  2. Verge
    Verge [H]ardness Supreme
    6,236
    May 27, 2001
    my neighbors say no
  3. AliceCooper
    AliceCooper [H]ard|Gawd
    1,477
    Mar 25, 2007
    Screw the neighbors, even at this deal my wallet says no v.v
  4. KD5ZXG
    KD5ZXG Limp Gawd
    409
    Mar 24, 2017
    Still have a Sigma Pro A2 I've not had time to build a proper bin for.
    The other (of same) got shoehorned into a 1953 style Karlson K15.
    Too much woodwork and not really big enough for this cone's VAS.
    This time just go simple, lightweight. My bass doesn't even use the
    lowest notes. For music, anything under 40Hz seems pointless.
  5. nyt
    nyt Limp Gawd
    399
    Jan 28, 2008
    Everything in this post is pretty much rubbish.
    That said, this isn't a deal. The um18-22 was just on sale for $235 like 3 weeks ago.
  6. KD5ZXG
    KD5ZXG Limp Gawd
    409
    Mar 24, 2017
    Rubbish is a two man lift that has trouble with doors yet still isn't big enough to do an 18" driver justice.
    Been there, done that. Not going that road again, though long ago I had elaborate plans drawn to do so.
    A plain small box will be easier to carry and still more bass than needed to keep up with a live drummer.
    Any club you play is going to have thier own subs, ask you to turn down, so why bother?
    Really, bass guitar's low E is 41Hz. Drop D only 36Hz. 16Hz makes no sense for Heavy Acid Spacegoth.
    Have already done damage to buildings with less than 300W in the unoptimized Karlson that never went
    as low as the loudspeaker was theoretically capable. For theater rumble that might be important but isn't
    music, just place one of them thumpers under your seat. Instant brown note.
    The UM is 10x less power effiicient. So you need 3,000W and thick cables to do the same damage.
    UM is only rated for 1000W, so never going to be loud as the less expensive Sigma for all its might.
    We get carried away with one figure of merit and forget that it all has to work together as a system.
    https://www.parts-express.com/eminence-sigma-pro-18a-2-18-cast-frame-driver--290-427
    Elaborate plans as mentioned above. Untested theory to improve on 1953 Radio Electronics K15.
    See what I mean by "Too much woodwork". All this weight for a flappin paper cone? Will I build it
    some day to prove a point, maybe. But weighty internal folds seem extremely unsuited for travel.
  7. Nenu
    Nenu [H]ardened
    18,843
    Apr 28, 2007
    Is the 16Hz response in room or open air?
  8. nyt
    nyt Limp Gawd
    399
    Jan 28, 2008
    The enclosure is tuned to 16hz, so that's going to be ground plane.
  9. nyt
    nyt Limp Gawd
    399
    Jan 28, 2008
    The enclosure will do just fine with the um18, as has been proven many times. It's about 11 cubic feet net internal volume.
    Assuming nothing in music is below 36hz is naive just because of a bass guitar. Get out with that nonsense. It's not like these are being used just for music either, they see HT duty where LFE tracks go down very low as well.
    Sure, horns are more efficient, but they're giving up octaves of low end response.
    This was mic'd in room. Can't remember the track, but was likely something from kmfdm or pendulum. The subs in question are tuned around 14hz and highpassed, so that's visible in the response.
    Still, nothing about this is a deal. These are normal prices.
    That_Sound_Guy likes this.
