D
Deleted member 278999
Guest
I'm normally practically not ever, ever into pre-orders, but this game Day of Infamy is great. If you haven't already, I highly suggest checking it out.
It's by the same team that did Insurgency which is also a great game.
The AI of this game is surprisingly good. It's challenging. They're smart, but not in a cheating way. They're effected by things like smoke, react to noises that you make and so on.
This game is in 'paid beta' right now. As I mentally, I'm not really a fan of paid betas / pre-order games. But unfortunately the developers chose to go this route instead of an open beta. I will say that the game works great. It isn't an alpha beta as you get with other developers. It's nearly the entire game that they're tweaking as they add features.
Spec wise you don't need much to run it. You'll have to check minimum specs but my computer isn't even breaking a sweat running 165hz @ 1440p. I'm guessing most of your systems can run it with ease.
Keep in mind that this isn't a Battlefield type of FPS. There is bullet drop. There are tactics. It is not easy. But it is quite rewarding!
You can find the game on its website at
https://newworldinteractive.com/category/day-of-infamy/ and on the Steam at
Have you played this? Would you like to? What are your thoughts on what you've seen or what you've played?
