date modified sort in vista
Discussion in 'General Software' started by jcmuse, Jan 18, 2008.
  1. jcmuse
    jcmuse Limp Gawd
    329
    Feb 10, 2006
    Why can't i see this option? Is there some place i have to enable it? I want to be able to sort my files in explorer by the last date modified. Argg!
  2. pxc
    pxc Pick your own.....you deserve it.
    35,300
    Oct 22, 2000
    Right click the folder, select properties, select the customize tab (or press Alt-V, "Customize this folder" from inside the folder) and make sure "All items" is selected from the first drop down.
    I wish Vista would always just default to the All items view. It selects a bad default way too often. :mad:
  3. l3ender
    l3ender [H]ardness Supreme
    5,379
    Jan 1, 2007
    You can also just right click on the headers bar and select what you want shown:
    [​IMG]
