Dark Souls 3
Discussion in 'PC Gaming & Hardware' started by Blade-Runner, Jun 6, 2015.
  1. jiminator
    jiminator Capt Obvious
    10,923
    Feb 2, 2007
    supposedly you can beat the game with the short bow. unlike the others it can shoot out of a roll and so forth.
  2. Domingo
    Domingo Skip My Posts
    16,957
    Jul 30, 2004
    While certainly not exclusively, I used a Dragonrider Bow quite a bit. It's notoriously slow, but I'm used to the timing since I used it in the 2nd game, too. Prior to finding it, I used a shortbow for the first half of the game. Since you can roll like mad in this game, getting away from bosses and playing the distance game isn't too bad.
  3. pothb
    pothb [H]ardness Supreme
    4,997
    Mar 24, 2007
    Bleed is ridiculous in this game, wish I knew about it more earlier on... didn't really bother much until very late game.... I might NG a high luck bleeder type.
  4. Lmah2x
    Lmah2x Gawd
    858
    Apr 3, 2014
    I've been bleed building since release on 5 playthroughs. It took me forever to figure out how to make it work effectively. Now with all the testing that has been done I know how it works. I might try a heavier build soon though with a big weapon, I need a change. 180hours of bleed build gets repetitive. Been considering doing a poison+pyro build though as well.
  5. Domingo
    16,957
    Jul 30, 2004
    Can't say I've dabbled with bleeding effects in any of the DS games. How does it work exactly and what weapons do you recommend?
  6. jiminator
    10,923
    Feb 2, 2007
    some weapons have bleed build up, Flamberge being a good example @ 33/hit. Once it passes an enemies bleed tolerance it whacks away 18% of health. Some enemies are weaker to bleed than others, I think like that alligator rat thing.
  7. pothb
    4,997
    Mar 24, 2007
    From what I've seen on wiki, the corvian scythe is the best bleed weapon. And bleed works like maggots, where a bar builds up and then you suffer a massive hit from bloodlost. Using a katana is actually pretty good as well, but I don't know how it compares with most other weapons. Seems like luck affects it, and people suggest hollowing with hollow gem for luck over blood gem which adds 5 bleed to weapon.
    I think I'm going for sharp claws and daggers with high luck and dex. No idea how well that'll go though.
  8. Domingo
    16,957
    Jul 30, 2004
    How long does it typically take to kick-in and is it obvious when it does (in PvP)? I can picture hitting someone once, running like hell, and then charging in right as the effect kicks in.
  9. pothb
    4,997
    Mar 24, 2007
    I don't do PVP =/ but when it kicks in, you see a big blood splatter so pretty obvious for the most part. You have to hit continuously for it to kick in, it doesn't build up automatically, it only happens once it's built up form your attacks.
  10. polonyc2
    polonyc2 [H]ardForum Junkie
    16,340
    Oct 25, 2004
    the bleed bar works the same as in DS2...the Corvian Scythe also damages the person wielding it which is something to remember
  11. Absalom
    Absalom Gawd
    604
    Oct 3, 2007
    If you have the stats to invest, Anri's Straight Sword is really good as it scales with luck. Anri's also has low stats requirements, but most SL120 PvP'ers are going to be dumping points into STR, DEX and LCK for an Anri build. The luck investment also synergizes with bleed (why I mention it), making bleed something of a bonus (Anri's naturally has good base damage anyway) assuming you stock up on some Carthus Rouge.
  12. pothb
    4,997
    Mar 24, 2007
    Does Carthus Rouge get affected by luck, I wouldn't think so. It's a good luck weapon but not so much a bleed weapon. Indeed the Corvian Scythe has that issue... still, I wonder how it plays out in combat, since I never used it.
  13. Sodapopjones
    Sodapopjones [H]ard|Gawd
    1,799
    Aug 22, 2012
    Its the switching back and forth between ranged and 2h that screws me over most of the time....
  14. pothb
    4,997
    Mar 24, 2007
    That actually gave me troubles too, but i just started my bleed character, as a thief. He starts off with a bow on the offhand. This actually seems to be wonderful for this very issue. Pressing F twice kicks it from bow to 2 hands. From 2 hands, you have to press f then right click though.
  15. Absalom
    Absalom Gawd
    604
    Oct 3, 2007
    After thinking about it again, I'm not so sure now. A little research from here actually creates more questions than answers:
    It's not clear to me if the luck bonus applies to non-bleed weapons enhanced with Carthus Rouge. Obviously Anri's has a 0 bleed aux value until you apply CR to it (then it becomes a temporary ~45 value). The question is, once a weapon's attacks start contributing to bleed status does the luck bonus always apply? Seems someone would have tested this by now.
    Bleed damage isn't exactly reliable damage. It's percentage based and proc'ing it requires multiple hits within a time window. It's a good way to keep someone on their toes in PvP though.
  16. pothb
    4,997
    Mar 24, 2007
    Don't know about PVP, but those 2 sulyvan's beasts were giving me a hell lot of trouble. But when I used a carthage rouge on my katana, I instantly killed it. 1 Heavy hit, into riposte = one dead Sulyvahn's Beast.
  17. Sodapopjones
    1,799
    Aug 22, 2012
    I'm glad I'm not the only one!
  18. Domingo
    16,957
    Jul 30, 2004
    I haven't messed with it beyond just trying out the moveset, but I read on another forum that the Lothric Knight Greatsword is a pretty killer weapon. It always hits with lightning, but I guess it can be infused further and it does massive damage.
  19. polonyc2
    16,340
    Oct 25, 2004
    reading the last few pages of this thread about all the different amazing weapons, armor and builds really makes me appreciate the game even more over Bloodborne's limited build options...although BB is still right up there with DS1/DS3 as far as best 'Souls' game
    Domingo likes this.
  20. pothb
    4,997
    Mar 24, 2007
    +9 bandit dagger is not doing it for me >_> I can bleed a hell out of stuff but the range/sweep makes it hard to fight groups and the lack of poise damage can get you killed.
  21. Domingo
    16,957
    Jul 30, 2004
    One of the neatest things about the Souls games is that you do have so many strategic options. Not every weapon/spell is great, but it does seem like most can range from serviceable to awesome depending on your upgrade path, stats, and playstyle.
    I enjoyed Bloodborne, but I feel that there are only about a dozen realistic builds and probably less than 25 stylistic approaches to the game.
  22. Lmah2x
    Lmah2x Gawd
    858
    Apr 3, 2014
    For bleeding you would want the dagger in your left hand with bleed infusion. Then use a hollow weapon in the right or something like Anri's sword, then apply Carthus Rouge to that. Proc bleed with left hand then Build up with right, you can do up to around 28% bleed damage per proc, forgot the exact numbers... since I've been playing sorcery lately.
    After you see the explosion always restab them a few times with the dagger, then keep beating to a pulp with the main hand.
  23. pothb
    4,997
    Mar 24, 2007
    Actually, after I said that, I started playing today and yesterday and I'm doing really good. Haven't died to an enemy yet.
  24. polonyc2
    16,340
    Oct 25, 2004
  25. addictedto60fps
    addictedto60fps [H]ard|Gawd
    1,329
    Mar 31, 2010
    This new patch has made my stuttering worse in this game. Anyone else seeing the same thing? What I mean by stuttering is the game will be running at 60 fps, then all of a sudden, will drop down to 58 and then shoot back up to 60 fps all in the span of a second, thereby causing the game to stutter/hitch. Now, the drops are far more severe, as I've actually seen it drop all the way down to 48 or so.
  26. pothb
    4,997
    Mar 24, 2007
    Man, I was dominating for a while, though I have died to falls >_> but then the npc invader in untended graves killed me 3 times.
  27. silent-circuit
    silent-circuit [H]ardForum Junkie
    16,133
    Sep 18, 2005
    Great, so they brought the stuttering back. Feels like no one at From does play-testing on these patches.
  28. addictedto60fps
    1,329
    Mar 31, 2010
    It was never fixed for me. I've always had it since I bought it a month ago. :( It's not freezing like it was like two patches ago or so, but the microstuttering is pretty bad in certain spots.
  29. Domingo
    16,957
    Jul 30, 2004
    No issues on my end. I made a couple quick runs through familiar spots and didn't encounter any of the pausing from last month's patch. Prior to and after they fixed it the game has run like a dream for me.
  30. DPI
    DPI Nitpick Police
    10,956
    Apr 20, 2013
    No stutter here. Single 970 @ 1080p
  31. addictedto60fps
    1,329
    Mar 31, 2010
    Anyone have any idea what might be causing it, for the people who do have the problem.
  32. polonyc2
    16,340
    Oct 25, 2004
    Dark Souls 3's final boss on NG+7 at Soul Level 1, no armour and only using a torch as a weapon...some people have way too much time on their hands...
    Armenius likes this.
  33. pothb
    4,997
    Mar 24, 2007
    No kidding, if that's true. That seems like it's way overboard with the limitation difficulty.
  34. jiminator
    10,923
    Feb 2, 2007
    I started a SL1, got as far as pontiff. Not sure I want to go further, difficulty really ramps up and it becomes a heavy time investment. For dude in the video, that is 23 minutes. That is a long ass boss fight.
  35. LurkerLito
    LurkerLito 2[H]4U
    2,116
    Dec 5, 2007
    Dam...definitely not for me. I don't even want to go to NG+ cause it might take me a little longer to beat stuff down. I finished 2 characters already both NG characters.
  36. jiminator
    10,923
    Feb 2, 2007
    NG+ is not that bad. In DS1 there is a huge jump from NG to NG+, the enemies have about 2x health. From there it increases to about 3x health at NG+7. DS2 & 3 there is a much smoother linear progression in comparison
  37. Domingo
    16,957
    Jul 30, 2004
    When boss fights (of any sort) go over 4-5 minutes, I tend to get fed up. The concept of a 23 minute boss fight sounds like torture to me.
    NG+ usually isn't too bad in the older games. After all, you know the game better and your stats/gear are a hell of a lot better. In DS2, the game might actually be easier in NG+. You're able to boost your stats up enough to rock the Havel set full-time much easier and you can respec nearly at will. However those DLC levels are absolute torture. Dark Souls 1 eventually gets pretty rough in NG+, but it's only the last 1/3 and DLC areas.
  38. polonyc2
    16,340
    Oct 25, 2004
    23 minutes is probably how long it took me to beat Ornstein and Smough during my early Dark Souls 1 days...those were some long battles...
  39. Domingo
    16,957
    Jul 30, 2004
    That's like the exact opposite for me :p
    That's a fight I tend to either win quickly or just lose. I doubt I've ever won that fight in over 3-4 minutes. Too much room for error, so I tend to lower the boom on the first one in the first 20-25 seconds. From there, the next 2-3 minutes are a 1-on-1 fight.
    I think the one fight I tend to take a while with is Kalameet. Mainly because it's fairly easy if you play it a certain way and I'm always trying to get the tail drop weapon. I've stretched that fight into a 25 minute affair trying to hit his damn tail.
  40. Comixbooks
    Comixbooks Ignore Me
    12,871
    Jun 7, 2008
    Damn I didn't know this was a Final Fantasy Sword =)
