I'm considering this cooler for my next project. I may want to paint the top cover a difference color, and that'd be easiest if I could remove it entirely from the cooler. That raised a couple questions:
- I noticed the cover is secured at its corners. Can someone confirm those are hex screws and not rivets?
- Are the black heat pipe caps part of the top cover, or separate parts? I'm hoping that removing the top cover either leaves the heat pipe caps in place, or that they can otherwise be separated from the top cover so I wouldn't have to worry about taping them off.
