dondan
- Apr 15, 2013
Here is a small update what I plan to do with the HSLP-48 in the next weeks.
I will test the following setups all CPUs @ default clock:
I will test the HSLP-48 Copper and Alu version following fans:
What I can say about the Lian Li samples, the quality is great for a prototype, but they forgot to include the 2011-3/AM3 retention bracket. They forgot to add a thread on the 1151 brackets so I can't use them. Therefore I use my Thermalright retention kit that I have for all sockets. What luck the Thermalright retention kits are full compatible to the HSLP-48 XD
I have to improve the fan clips because the two ends that go inside the heatsink are very short. I have to make them longer to better secure the fan. I also plan to add more holes for the clips to better support different thickness of fans.
I think I will get the CoolJag samples tomorrow, I hope they did a better job on the retention brackets.
I am thinking of outsourcing the retention kits to Thermalright if they can offer a good price. The brackets are the most complicated part on this project and it could be a good idea also for future compatibility. I will ask Lian Li if they can get in touch with them and I don’t have to take the route over the German contact.
Preview
Here is small preview of tests on the copper version I did today. All values are not comparable to older result, because I run the CPU (i7 5820K 140W TDP) on default clock (3.4GHz) and voltage. Older tests was made with 3GHz and lower voltage. The Dynatron T318 will reach ~80°C on default clock and voltage.
Prime95 v26.6 8K Test – 15min each
Heatsink------------Fan---------------Position-----Mode----------RPM--------Room Temp--------Core Temp
HSLP-48 Copper.....A9x14...............Under......Pushing..........2600..............25........................74 °C
HSLP-48 Copper.....A9x14...............Under......Sucking..........2600..............25........................65,8°C
HSLP-48 Copper.....TY-100..............Under......Pushing..........2400..............25....................... 65°C
HSLP-48 Copper.....TY-100..............Under......Sucking..........2400..............25........................63,8°C
HSLP-48 Copper.....SY1212SL12H..Under......Sucking..........2000..............25....................... 65,2°C
HSLP-48 Copper.....A12x15..............Top..........Pushing.........1800..............25........................63,5°C
HSLP-48 Copper.....A12x15..............Top..........Pushing...........900..............25........................73,5°C
Maybe you wonder why the A9x14 performs not good in pushing mode. I think the fan has a bad pressure and isn't able to push enough air through the fins in this mode. What I think is realy crazy that the heatsink is able to cool a six core i7 in Prime95 with the new A12x15 on top with only 900 RPM at 73°C. I am nure sure if any other heatsink with a height of 63mm is able to do that.
Some pictures
- AM4 (1700x)
- 1151 (7700k)
- 2011-3 (5820K)
- Asetek 92mm AIO (AM4, 2011-3, 1151)
- Cryorig C7 (AM4, 1151)
- Noctua L9i (AM4, 1151)
- Dynatron T318 (2011-3)
- Thermalright AXP 100 (AM4, 2011-3, 1151)
- A9x14 (92mm)
- TY-100 (100mm)
- SY1212SL12H (120mm)
- A12x15 (120mm)
- under the heatsink sucking through it
- under the heatsink blowing through it
- on the heatsink blowing through it
- sandwich mode
- different fan speeds
Preview
Some pictures
