TheMeanCanEHdian
- Dec 7, 2017
The new C4 design, for sure.
I kind of like them being the same style, it's more like a family/range of cases. More cohesive from a branding point of view.Today I made a small test how a A4 design would look like on the C4. Do you like it or do you love the C4 design more?
Yes I can do it but it will take some time ^^
Will we be able to still put 3 HDDs (well, 1 SATA SSD and 2 HDDs, for me) in there while using a setup like this? I really wanna get that case with a glass panel (i hope those will be smoky and not just clear ^^) then
ooooh thats great news, thanks!The distance is the same![]()
Been thinking about what watercooler I could use once this is done and gets delivered, to move my A4 build into.radiator thickness 30mm with 2x 25mm thick fans
Does not fit.That eisbaer version looks good. Do you think this would fit? I'd love if it did, don't know where are the rad dimensions or at least length.
https://www.anandtech.com/show/12090/ekwb-announces-ekmlc-phoenix-aio
Can you do the maths , please?
