Sigh, what a shame. The contrast line behind the front plate is what made this case unique looking. With the new sides, it not only looks a lot more like any other case, but also looks a lot more like the Anthoo cases with the bends on the side panels.Here is the result of the third poll:
In total, design A got 475 points, design B 653 points and design C 523 points. Only 15% of the survey participant gives the Design B 1 point. Design B is the average winner.
AIMiDaX a Hardforum Member, has another idea for a design that looks also very nice, but it could be difficult to manufacture it while keep the rotating feature. So currently I think about how I can make it fabricable.
A word about window kit: My plan is to offer two versions of the case. One version with a window kit and the second without. In reverse conclusion this means that every design I had shown in the last weeks will be window kit ready. So please don't make your decision based on renderings that shows a window kit, because it is not limited to one design.
Here are some pictures of the winner design:
I'm with you on this one. The original look is far more authentic and memorable than this new diagonal 45 degree (boring) cutouts.Sigh, what a shame. The contrast line behind the front plate is what made this case unique looking. With the new sides, it not only looks a lot more like any other case, but also looks a lot more like the Anthoo cases with the bends on the side panels.
theGryphon: And why you did not vote for it in the survey?
no wayYeah, I agree, the original was the best (especially if side IO is a must)...
I will show you a 240mm AIO solution in the next days that will allow you to easy upgrade it with copper water GPUs heatsinks from EK, Koolance, Alphacool s.o. Futhermore I will also show you how you can easy refill it.
Thanks alot exactly what i was looking for.You should look at the Ghost S1 from Loque thats exactly what you are looking for, seperate GPU/CPU compartment, top or bottom or both radiator support available through Tophats
I'm sorry to post that here dondan, but did you saw that ? I don't really know if this is legal...
https://www.cowcotland.com/news/61046/boitier-pc-mini-itx-kolink-rocket.html#last
I think new trend of pc cases is tempered glass without hand screw
as dondan said, maybe this thing makes case thicker.
anyway... beautiful
Dan, hello. Enthusiastic backer of the A4-SFX v2 here, eagerly awaiting its arrival.
Can you elaborate on this? If I've followed the thread properly Alphacool's GPU waterblock fits, and with your recent adjustments their 240mm radiator does as well – but their CPU block+pump+reservoir is still a bit too large.
IMO the design of C4 makes it an ideal platform for CPU + GPU water cooling. Given with the rising popularity of modular/quick-disconnect cooling systems, ISTM that if you could demonstrate an end-to-end, low-maintenance, dual cooling solution for the C4-SFX, that would be a significant selling point for the case.
Any chance you can talk Alphacool into making a CPU block that fits the C4?
ive been downsizing cases from a full tower to a dans case so i can make myself a vrbackpack. the problem is my vid card isnt a blower style type and it heats up fast. so i set myself on a mission to try to fit a aio cooler on my 980ti non reference card that works with a 92mm rad that fits in this case. i found out that a kraken g12 with a 92mm asetak cooler actually works well and fits too. but im planning on making my cpu aio too so i going to take out the psu and mount it on the outside of the side panel and use that space for the second 92mm aio cooler for the cpu in its place. the power cables are going to be run threw the power plug hole since i dont need it inside the case anymore and dremel the side of it so i have a opening for the cables, cuss the only thing power wise that pases the motherboard is the power for the graphics card( which i could us that open io slot for gput) and sata power for the harddrive.
dondan, with the (significantly?) less expensive PCI riser in the A4 v3, will you reconsider the hard riser in the C4?
Looking forward to the C4. Missed the A4, looking for another small ITX to follow my Ncase. Hope release date of "may 2018" is still on track![]()
You loose he ability to choose between 2.5slot graphics cards or bigger CPU cooling if you go for the split chamber design though.dondan, with the (significantly?) less expensive PCI riser in the A4 v3, will you reconsider the hard riser in the C4?
"DAN C4-SFX: A water & air cooled SFF case"What ‘bigger CPU cooling’? The entire design is centered around waterblocks.
it also is "water & air cooled" if you watercool the CPU, as intended - as the GPU will be air cooled. there was also no need for the bigger font."DAN C4-SFX: A water & air cooled SFF case"
Hey: calm down.
If you only want air cooling I think Dan has a case that's ready to buy.
There's a whole thread about it somewhere around here...
I am thinking of renaming the C4-H2O.
I am afraid, that somebody can think that this case is only made for water cooling. This is a real problem, because I think the air cooling efficiency of this case is better as it is in the A4-SFX.
dondan Reading the forum, I hope this feature/ edit has not been overlooked/forgotten.![]()
I understand the many changes and renders have been already been implemented, but I would really like the option to include 2 additional fans on the bottom of the radiator (max height 12-15mm). Is this something you can add to the renders/work plan or have you completely decided not to go with this.
Again, I believe this to be an amazing feature that would allow for more/better cooling. How it looks with the current renders and with the 180 rotation, i dont now but I'm sure that you could put something together.
Happy New Year![]()
I don't like how the GPU covers the motherboard. Now-adays even the motherboards being manufactured are nice to look at, and I don't think many people would want crap blocking the view of their motherboard. Not to mention, you are making it unnecessarily hard to access motherboard components for trouble shooting and upgrading etc. I like the integration of the space for a 240 radiator, but you should keep the dual chamber layout the A4-SFX had and I would possibly replace my Ncase M1 with this. I am sure other folks would share my criticism.
There isn't really any beneficial attributes this case has over the A4-SFX V2. It still doesn't look as though you could do a custom loop and cool both CPU and GPU because of both getting in the way of each other, but I could be wrong. If you are just planning to use an AIO to cool your CPU, stick with the A4-SFX V2, because it can already do this is is 2 liters smaller.
I for one, don’t share your criticism. The primary design doesn’t account for a window, so there is no view on the motherboard in any case. Even with a window, I wouldn’t mind just seeing the GPU and having the mobo behind it.
Accessing mobo components is not something you do often, the design really doesn’t have to accommodate for this, it’s a super compact case after all.
The whole point of the design is to reduce production time and cost over the A4, and one of the main factors is the flexible riser. With the alternative hard riser you cannot have a dual chamber setup.
