Aircoookie
- Feb 6, 2015
Why do you want USB 3.1?
Just future-proofness. I'd like to keep that system for a few years and with ITX there's no possiblity to add IO PCIe cards
Maybe I'll go non-K i7-6700 with L9i then. If there were only a good H170 board with USB 3.1... since otherwise I could even stick with Haswell. Looking forward to the test with 6700K and C7 in the A4. My priorities: Size > idle noise > performance > load noise
Ok then try repaste maybe that helps.
You can try three things:
Testing the hardware outside of the M1. I think in the M1 the Cooler will recycle hot air. Because there is to much left room between outside and fan. If you get better values you can add +1-2°C and you have the value inside the A4-SFX.
Maybe adding a 120mm FAN over the CPU on the sidepanel in the M1 could help.
You could also lower the temp by undervolting the Xeon use the offset mode: -0,06v -0,09v should be possible and helps to lower the temp between 5-8°C.
It could also be that you got a hot chip. For example if you have 10 Xeons E5. Maybe 2 will be under full load 70-75°C, 6 will be between 75-80°C and 2 will be 80-85°C.
If you reduce the target clockspeed, you can lower the voltage more but real undervolting means having the same power with lower voltage.
For my daily use case I set the max multi of my 5820k to 30 and undervolt the CPU in offfsetmode to -0,125V. In prime95k I have max temps around 66°C. I don't need more CPU power, because if I play I only play Diablo3.
I setup a custom fan profile in the ASrock UEFI. Up to 50°C CPU temp 30% fan speed, from 50-60°C up to 60% fanspeed, from 60-70 up to 80% fan speed and if i got more than 70°C the fan will go to 100%. Make sure that you setup these for all fan tables and link it to the CPU temp, because customize fan tables are buggy. It could be that the CPU fan use a different fan table after rebooting so setup it for all tables. There is also another bug. If you setup a custom fan profile and you go into the bios and change the voltage of the CPU the bios will lose all custom fan profiles.Maybe I have to update the bios
@dondan - I don't know if you saw the question asked on the previous pages, but with the new manufacturer, any chance on an earlier release date?
New manufacturer? Is LianLi out of the game?
I noticed the Broadcom BCM94360CD is 57mm long. I also noticed the max cpu heigh is 48mm. Can I safely assume this Broadcom card will not fit?
I might've read wrong so please take what I said with a pinch of salt. Looming back now, I'm unable to locate where dondan said something about it.
On a side note, what do you guys recon the chances are you'll be able to squeeze a EVGA 980ti GAMING AC 2.0+ SC+ into this case? I'm worried about temps...
By the way if my deal works with the reseller I don't need a crowdfunding campaign, because they ship worldwide.
Vcore Voltage Additional Offset is the right value.
Hey Dan,
Thanks for your help, I'm now getting mid-30's idle and mid-70's at 100% load with a -0.11 undervolt. I'm tempted to try and push it further down to -0.125! Everything seems stable at stock clocks.
This is in an M1 with all the side panels off. Looking forward to trying this in an A4!
For those thinking about LGA 2011 in the A4, it looks like this will be possible, at least without overclocking!
This is great. What E5 do you use?
Wow, 12 cores inside the A4-SFX this whould be sheer madness.
Yeah! The Asrock X99 ITX board has really opened up some new opportunities.
My crazy dream is to use PCIe bifurcation to put two ITX sized GPU's side by side with water blocks in the GPU compartment. Then, I want to design a custom outflow valve so liquid enters exits from above rather than from the sides of the card. Finally, a radiator will go behind the PSU enabling a 12 core SLI or CrossFire build in ~7L.
Gonna have to be two R9 Nanos then, I believe all the other ITX GPUs out there are all dual slot even after switching the bulky stock coolers for a water block, because of the video out ports
What pump/res you gonna use, and where is it gonna go ?
Gonna have to be two R9 Nanos then, I believe all the other ITX GPUs out there are all dual slot even after switching the bulky stock coolers for a water block, because of the video out ports…
What pump/res you gonna use, and where is it gonna go…?
At that point a Fury X2 seems to make a lot more sense.
@All: Some asked i this thread if there is a bag for the A4-SFX. Maybe this one will fit:
http://www.amazon.de/Lowepro-Event-...5&sr=1-2&keywords=Lowepro-Event-Messenger-150
Holy shit, are you me? Thats exactly what i was thinking about the last weeks. The R9 Nano might be the perfect (yet expensive) candidate for a project like this. I didnt like the card when it first came out, but with its uniquely short PCB at 15,3cm it will allow a 120mm rad, maybe even a 140mm, depending how much space the front-oriented powerplugs take.
With the new 1-Slot liquid-cooling options from EKWB or Aquacomputer a "Sandwich"-Crossfire-Setup should be possible.
Like you pointed out, it will require a custom-made bridge-like connector part that will replace the stock connectors on both waterblocks. I'm thinking of a shared block-type connector, that splits the waterflow into two channels. I should fire up solidworks and do a CAD-Modell of this...
KSliger reported here https://smallformfactor.net/forum/threads/two-portable-sff-gaming-cases-under-7l-and-under-5l-w-500w-psu.200/page-2#post-4146 that other boards do support bifurcation:
"Some boards require a resistor modification (Z97E-ITX/ac-n), others like X99 need a BIOS flash and then there's some that work with bi/tri/quadfurcation right out of the box like Quanmax KEMX-8201..."
Might I ask what is the point of having these wings at the back? Does it fly?
There are others thinking about similar builds! Although not necessarily in the A4:
http://hardforum.com/showthread.php?t=1870298
Important notes:
- Only the Asrock X99 ITX board on the P1.20E BIOS supports PCIe bifurcation at this time
- This seems to be the best candidate: http://www.ameri-rack.com/ARC2-PELY423-C7_m.html
I'm hoping there will be other options besides the R9 nano next year for this type of project, it is quite expensive! Maybe Nvidia Pascal or AMD Arctic Islands will have more cards like this.
A shared block-type connector would be the way to do it! I'll be curious to see what you come up with in solid works.
As for radiator and pump, I'm having trouble finding things that would be small enough. Dondan, do you know the width of the GPU compartment? Edit: from earlier in the thread, it looks like 40mm thickness max.
http://s28.postimg.org/5pu6tubil/a4sfx_7.jpg[/IG][/QUOTE]
Those tabs are to assist in removing the sides.
Some very quick mockups as how i think such a bridge could look like. Since i dont know the exact dimensions of the EK-cooler, measurements arent accurate. I haven't found any blueprints online so far. The biggest drawback would be the fact that such a bridge needs to be manufactured in two parts, as the connecting cavity cant be milled into it any other way.
Since the laing-based pumps are the smallest available, i would absolutly go for one of those, be it the EK one or another. I think one should fit on the bottom, if you have no ssd's placed there.
Another thing to bear in mind is the fact that you need to unscrew the PCIe-risercable, and with a ribbon for pcie-bifurcation, the room under the graphics cards will be pretty crowded too. And both GPUs are only supported by the IO-Bracket then. Anyways, nothing that cant be overcome i think.
