Curiositie
- Jun 4, 2014
Edit:
aha
Was asking about the top screws, I'd just never noticed them until that render.
aha
thinked, (or thinkered?!)
There is "thought", past tense of "think", and "tinkered", past tense of "tinker".
Hi guys, I have some questions for you. I bought an NCASE M1 for my new computer that will be completed in this november. However the case is quite bulky and it fills entirely the cabin sized backpack that I bought for it. I'm thinking to switch to a DAN A4 by mid 2016, but I don't know exactly what to buy (I only have an SX600-G PSU already bought). So my questions would be:
1. What would be the maximum size (w x h x d) of the video board ? (Thinking about MSI GTX 980 Ti Gaming)
2. Can I use both a 3.5" HDD and a 2.5" SSD ? (if not possible, I would ditch the SSD...)
3. How much room do I have for the CPU cooler?
Thanks!
all of the answers are here:
https://www.dan-cases.com/dana4.php
1. 980Ti Gaming will fit ( max size is 40x144x295)
2. no support for 3.5" drives
3. max height 48mm
Holes or mount for external 120 240mm radiator would be very simple.
I think a while back in the thread he mentioned that you can thread the hoses through the IO area of the mobo for an external rad. With a bit of creativity maybe you could mount a rad internally in the GPU chamber if you're going for an ITX GPU?
Hey, earlier in this thread I did some calculations for an internal rad. If you use an ITX GPU, you could fit a 25mm rad with a 12mm fan in the GPU chamber. The trick would be fitting your pump and reservoir below, but it may be possible. Dondan concurred!
Heh, nice!
That being said I personally wouldn't want to sacrifice full length GPUs for a liquid cooler in that spot...if I was hellbent on liquid I would just go for an external rad...but that carries a penalty in terms of footprint.
I wonder if you could use an external PSU and use the space for a rad there...admittedly I know nothing about external PSUs so I don't know if that's a realistic thought
Heh, nice!
My thought was to place two ITX GPUs side by side and have them on single slot liquid cooling, this would give you more than the performance of a normal full length GPU! Possibly this could be done with 2x R9 Nano.
Sure, anything is possible if you get creative, but current external PSUs don't have the power to support a setup like this...
Depends on how you want to do it. If you want a GPU and a good CPU, you'd either need an external SFX PSU which requires a lot of modding to look decent, or you could go with two external power bricks. I don't think there's a single brick that can supply high end cards and 100W+ CPUs with power at the same time without melting. But if a 970 or 960 was enough, then a single brick could be sufficient.
Either way, you'd still need a spot for the DCDC converter inside the case.
It doesnt change dimensions of the case, what is needed :
1) holes for WC
2) frame for radiator
That's it very simple.I think WC was dismissed because the author is too much love into art/design instead of functionality.External radiator isnt cute but for people who would like to use X99 seriously or overclock it would be very appealing to have such option.In second image, in fact if two fans would be mounted facing down the top of the case they would cool down MB/RAM by taking air out and then cool CPU by cooling down radiator.
http://s28.postimg.org/eyzclwc7x/0000.png[/IG][IMG]http://s27.postimg.org/xiu7us1sz/0001.png[/IG]
There [B]should be[/B] holes in side of the case for WC pipes.And screws/mount for 120 - 240mm external radiator on side of the case as it is 327mm long [U]for [B]people who need[/B][/U] some serious CPU cooling.
Now you can still do it but its much moire clumsy as you need to have open case.
I think best solution would be mount frame for 240mm or even 380mm radiator on top, as it would cool down CPU space between radiator and case would be enough to keep cooling of mb/ram intact.With some holes and this mount you could
WC and overclock CPU and even CPU/GPU.
It doesnt change dimensions of the case, [B]what is needed[/B] :
1) holes for WC
That's it very simple.I think WC was dismissed because the author is too much love into art/design instead of functionality.External radiator isnt cute[B][COLOR="Red"] but for people who would like to use X99 seriously or overclock it would be very appealing to have such option.In second image, in fact if two fans would be mounted facing down the top of the case they would cool down MB/RAM by taking air out and then cool CPU by cooling down radiator.[/COLOR][/B][/QUOTE]
Lol
You aren't in the target market of this case then, plain and simple. I love how you just joined and are dictating to someone how a finalized product needs to change at the 11th hour to accommodate your edge use-case.
You [B]should [/B]design a case for [B]the needs[/B] of those people and not expect others to do it for you.
Oh btw for everyone who want's to watercool: If you mount the PSU reversed by 180° you can use its fan to pull through the radiator if you need something a bit thicker. If you want to mod, you could also reverse the fan and use it as a pusher.
I got their machine shop right here:+1 to silentbob and iFreilicht
The case was't designed with WC in mind, if you need WC JFK, get the Ncase or modify the A4, if the mods are as easy as you say you should have no issue getting a machine shop to help you.
The HD PLEX 250W power board if properly cooled can do 400W with an external brick. There's a test floating around here somewhere.
Lol
You should design a case for the needs of those people and not expect others to do it for you.
The HDPLEX doesn't have the connections for two cards. If it did, there still is no two-card combo that the HDPLEX is capable of powering that wouldn't be better served by a single card.
Look at the ports on your single slot waterblock of choice. Now imagine connecting two together. Does it fit in a dual slot space? AFAIK, there is no way to fit two single-slot waterblocks in a dual slot space.
