The problem is with the current CPU cooler height restriction in this case (48mm) there's not enough room for a 120mm fan+heatsink without violating the maximum component height of the motherboard.I wonder if we can get a manufacturer like Silverstone or Cooler Master to make a low profile 120mm cooler that would fit in the A4.
I mean there's space over the PCI-E slot, which most "Mini-ITX" coolers have to avoid because it would hit the GPU. On the other hand, in the A4 there's a PCI-E riser there so they should be able to fit more fins in that area, and the area on the opposite side.
After lurking this thread for a year I made an account just to tell you that your case is amazing and that myself and the thousands of other lurkers are very excited to buy it.
First of all thanks for the detailed explanation*snip*
That cooler is 10mm more than the max height in the A4, but you can see if the height were reduced by that much there would only be enough space for either the fan or heatsink fins, but not both.
Been behind the scenes as well and I agree with you on this one. The case is amazing! I'd get a USB port cover though to mask that tinge of blue in the front.
Here's to hoping that the prize will be just as attractive upon the kickstart launch date.
And yes, this case is enticing not only for uSFF enthusiasts. The folks in the eGPU community are still waiting on this case as it is easily one of the most compact GPU+PSU+cooling cases you can find.
Not impossible, just impractical. Cooling 130-160W in this little space is going to be a challenge no matter what. A 1U copper finned heatsink + slim 92mm fan might work, though I'm skeptical something like the Noctua fan would have the static pressure to push enough air through the tight fins on those heatsinks. An alternative is a 1U blower cooler, but I can guarantee you wouldn't want to be in the same room with it if you value your hearing or sanity.First of all thanks for the detailed explanation
Secondly... I'm sad
It seems we'll just have to make do with NH-L9i or something similar.
I'm really interested in the Dynatron cooler with X99 though, I've been reading around. I read somewhere that it wouldn't work with a fan over it, because the fins/heatsink are designed in such a way that air is forced over it in one direction (like in server chassis). I figure X99 in the A4-SFX would be impossible if that were the case (at least for now)
..I'm really interested in the Dynatron cooler with X99 though, I've been reading around. I read somewhere that it wouldn't work with a fan over it, because the fins/heatsink are designed in such a way that air is forced over it in one direction (like in server chassis). I figure X99 in the A4-SFX would be impossible if that were the case (at least for now)
I think a 92x92x20mm fan will also work with that heatsink. We should find out soon what fan configs work the best, but i'm guessing fans that are close to the side panel will work better.hmm.. Black5Lion: to give you an idea, a dynatron T318 + NF-A9x14 should work.
Now with that said, I would prefer allowing for the more widely available 58mm HSF setups. Not sure how much would need to change and if that is a feasible change at this juncture.
The case is too small to support tall CPU coolers and im am not willing to make the case larger to support coolers taller than 48mm.
The current offering of low profile CPU coolers are able to sufficiently cool a Core i7-4790K with good temps and noise levels.
I meant since the fins only go one way, the air has to go in one direction (or two if the fan is on top of the heatsink).forced what? cant you take conclusions of how it works from the pics? jesus, for someone who claims to do x265 encoding you sound pretty dumb dude.
This is what I've been wondering about, should work is theoretical. I want actual tests that not only see if the CPU doesn't throttle, but what temperature it runs at and what noise levels.hmm.. Black5Lion: to give you an idea, a dynatron T318 + NF-A9x14 should work.
The silverstone AR05 should work with a total height, with fan, of 36.7mm.
The Silverstone AR05 is an LGA115x cooler though It would work with 2011-3.
I doubt he could change the width of the case at this point, and even if he could I wouldn't recommend it. Since it would just make the case bigger, and the NH-L9i/AR05 are already good enough if you don't overclock. In addition to the fact that increasing the width to fit bigger CPU coolers would leave wasted space in front of the PSU.
this is a very specific build oriented case, you cant stuff whatever you want into it, if you want x99 you might have to look for something else. i'll be doing mine on a ft03-mini for example, reasons are flexibility and because i find it cute
I wonder if one could pair a 120mm fan with one of these heatsinks.The Silverstone AR05 is an LGA115x cooler though It would work with 2011-3.
Maybe a slim 120/140mm fan could be mounted to the side panel instead of the heatsink.
That is whay I was planning to do with the deepcool gerstorm 120x20mm fan. I purchased the x99e-itx, dynatron t318 , fan, ram, 1tb ssd, psu and all I need is for my sister to stop by microcenter to get the 5820k. Once I have all the parts I will try and simulate the A4 to see how manageable the temps are. I'm really excited for this case and my build.
Is there actually hype and discussion on this case in the eGPU community? That's awesome!
Yeah, I realize there are sacrifices to be made. We'll just have to wait and see how it performs
that cooler is inefficiently designed for a height-constrained system. can you imagine video card with coolers like that? they'd all be 3 or 4 slots thick!
ITX motherboards need to be designed with low-height components around the socket, and the cooler heat pipes need to be replaced with a vapor chamber (equally effective, but lower height)
You still have the backpanel with some ports and current boards tend to have more of them now rather than only two.
Yes I know you aren't limited to one total USB; it's would be more of a convenience thing since you're going to be walking around your room and will probably want as much cable as possible.
That said they might mean one cable for the HMD and one for the camera, so it may not even be an issue.
This forum is now a VR chat room...if usb length is an issue buy a usb extender or hub. Options are out there. Dondan has stated multiple times that the system is in it's final stages and doesn'twant to make changes if not needed. Usb placement and quantity have already been discussed and the majority vote was 1 front usb.
I was talking about AR as the M$ HoloLens. Anyway what you stated is a ton of hacks and stuff required to make it work that will make the experience worse or more expensive.Yeah, the walking around stuff will be new to the consumer version of the Rift. DK1 and DK2 were officially "seated experiences", but the Vive allowed you to walk around a small room (it also knows where walls are and puts up a virtual grid to let you know you're getting close to a real world wall). In response to all of this Oculus said that the Rift CV will have better standing-up capabilities and will allow you to walk around.
It's not lack of enthusiasm for VR in general but being cautious with ideas of moving around with VR headset. We're excited about VR and there are already few studios around in my country that are making the VR dedicated games but at the same time there's also a ton of new other stuff that we're focusing on like physical based rendering and using 3D scans in games(Check out "the vanishing of ethan carter" and "get even").I'm actually surprised at your guys' lack of enthusiasm for VR! Having tried it I'm 100% convinced it will be huge!
(Also if the face in my original post didn't make it clear I'm not actually expecting dondan to change the design at this point, was just joking around).
I'm more excited for the "big screen" feel of VR rather than the "moving around in VR", also did you see Virtual Desktop (maybe pair it with Display Fusion to get 3+ virtual monitors)? That is something I could see replacing my monitor(s) once the resolution of VR headsets is good enough.It's not lack of enthusiasm for VR in general but being cautious with ideas of moving around with VR headset. We're excited about VR and there are already few studios around in my country that are making the VR dedicated games but at the same time there's also a ton of new other stuff that we're focusing on like physical based rendering and using 3D scans in games(Check out "the vanishing of ethan carter" and "get even").
It seems like it would work great for an eGPU case, but I think what Silverstone showed off would work better, we just need a PCB/port that's more common and works better/similar to thunderbolt.Getting back to the case talk - I really like the idea of using this case as a eGPU housing. It would be nice if lurkers from eGPU community made a mITX form pcb dedicated for use with standard cases and power supplies.
There are two challenges:
Latency
USB has two orders of magnitude higher latency than PCI. Many PCI drivers assume memory mapped access to registers on the PCI card with the CPU blocking on the bus transaction. Unmodified PCI drivers over a PCI-over-USB bridge are likely to fail because of wrong latency assumptions.
Check this study on PCI latency: PCI mean latency is in the order of 400ns, PCIe mean latency is in the order of 2000ns. USB 3.0 latency according to the article you linked is in the order of 30us.
Bus vs. Packet Network
While PCI is a bus, PCIe and USB are packet based networks. The PCIe root bridge hides the complexity of a packet network and presents the CPU with something that looks like a bus. Doing the same thing over USB is certainly possible, but if you want binary compatible drivers your hardware interface towards the CPU has to look more or less like PCI and you will end up with something like a PCIe root bridge. This is probably not something that can be achieved by common USB chipsets with *HCI interfaces.
What silverstone showed off? You mean that last year's CES ASUS/Silverstone XG Station 2? The thing about toys dedicated to e-gpu is they are seriously expensive because they are dedicated.
Making a mITX form factor compatible eGPU board is a far better idea than leaving that to laptop manufacturers that will most likely make a proprietary tech fitting only high end/expensive ultra thin laptops. with mITX form factor you get to choose all other parts from anywhere you want.
As for the interface - I think it's doable but probably would be slow or unstable. If I'm not wrong USB, pci-e and pci are the same familiy of pci devices seen by the operating system.
Someone explained its problems here:
http://electronics.stackexchange.com/questions/141579/how-to-make-an-external-pci-adapter-that-runs-on-usb3-0
Anyway I think we won't get proper eGPU support unless we drop the idea of having video output connectors on the card bracket rather than forwarding the output back through the motherboard and its connectors which would also benefit the console like form factor cases.
Sorry for going off-topic once again
Its not only good for console like form factors but mostly for the laptop eGPU's - currently you ether have to have proprietary transmission implemented in the notebook or you use the external monitor with the eGPU as far as I know. Which means your're converting your notebook in desktop workstation with screen, keyboard and mouse rather than simply attaching accelerator with cable while still chilling out on the couchAs you said, console-like formfactors would highly benefit. Not only would the rear bracket be used exclusively for exhaust, it would also limit confusion for the customer as to which HDMI port he has to plug his TV into and it would give more freedom with placement of the GPU.
