DAN A4-SFX: The smallest gaming case in the world
U can install there an 15mm fan with that 575 lc 92mm aio. So I think about 55mm without drives
SOOO, asetek 92mm AIO is gone for good? What our other option :( luckily im not planning to build anything unitl next year
Dang...
Well I have a small stockpile of Corsair H60 kits. I guess I could just replace the 120mm rad with a 92mm rad, but then I'll have to deal with filling it and getting the air bubbles out.
Alpenföhn® Black Ridge
https://www.alpenfoehn.de/en/products/cpu-cooler/black-ridge-en
Wow. This cooler looks amazing. It looks like the fan blows out rather than in. How will this work on the Dan Case as it is designed to take air from outside and blow it onto the cooler?
This was designed by Dan so it probably works well but I'm curious if anyone has any insights about how the positioning of the fan could impact temps/airflow.
Hey guys,
if you have an ASRock Fatal1ty AB350 Gaming-ITX/ac and want to instal an EKL Alpenföhn Black Ridge, you need to modity the cooler. See my other post.
But the EKL Alpenföhn Black Ridge is better than the NH-L9a-AM4.
Hey guys,
Did you have a fan duct on your L9a? How much better do you think it is?
Hey folks, just wanted to share a picture :D
Next pic probably will be in a few weeks or even beginning of next year :D I still don't have all the parts for the rig.
Pump isn't final, it's just a test-fit (different top will be used, for starters).
Richiegore, the fan duct on the L9a made the CPU 6-8 degrees cooler in my system.
So your saying the black ridge is better than the l9a with a fan duct? Do you have the IO shield in place on the back of you computer? Sorry for all the questions, there are just so many factors that can affect performance!
I really want to know how much better the black ridge with a noctua A9x14 fan will be compared to the l9a with a fan duct both with the IO shield in place...
What experiences do you guys have with M.2-drives behind the mainboard?
I'm asking primarily because of a) space (due to the thickness of the PCIe-extender) and temperature (as seen above, I do have a fan under the MoBo, but the extender will "shield" the M.2 from airflow anyway, doesn't it?).
I'm interested in this too. I've already ordered the l9a but as it's pretty hot where I live I think I'm going to need all the help I can get
Also, what was the deal with the USB type C front port up module? Just a rumour or something promised?
Just saw on sfflab a shorter version of the x16 cable (ADT) with a length of 185mm. I think maybe a 180mm version like this would be a better fit? The model we need is R33UF-TU. On sfflab they is a version named LiHeat, any news about it?
Just planning a new build with the new Blackridge and 2080 Ti with 2 case fan on the bottom. What would you recommend guys, CPU Fan blow air outside and case fan inside (maybe a problem with GPU because it sucks air in and blow it towards case fan) or cpu suck in and case fan blow out?
Guys, anyone has the exact dimensions for custom cables?
150mm for ATX 24 pin, 250mm for EPS 8 pin and 300mm for PCIE. This was for the Asus strix z270i, your mobo layout may dictate different lengths.
I have no experience with the Blackridge. Sorry i can not compare it with the L9a. With the L9a i still have the IO shield in place.
Hi everyone,
It looks like the new Alpenfön Black Ridge has some manufacturing problems. Some heatpipes are not soldered correctly with the base. Maybe you know I can’t give support by myself because it is not my product. My name is only printed on the carton because I helped EKL Alpenfön in the development process. However I forward the manufacturing problems to EKL and they ask me if I can post the following statement (I translate it from German to English):
“Dear customers, the first review samples were not affected by the problem, so we start producing the first batch with a rush order. This first batch is affected by the problem and is a result from quick manufacturing. We are very sorry about it. All already ready new batches and future batches will not have this problem. We informed all resellers. The resellers will contact you for a replacement process. We guarantee an easy replacement of the product. We feel very sorry that this happened due to quick manufacturing and we ask your forgiveness. - EKL”
Furthermore they confirmed that the current version with bad soldering will not perform as good as the flawless version. So everyone will get a new flawless version.
With best regards
Daniel Hansen
Interesting. So jury is still out on how this cooler stacks up. Good for them for agreeing to replace everyone's first batch, that can't be cheap.
Thar's what you get when you rush everything and ignore quality management. Nonetheless, the second batch will be ordered.
Hi everyone,
With best regards
Daniel Hansen
hi Don thank you for the update is there anyway we can tell if we are affected by the problem? I just got mine today or is it better to assume we are effected and contact the reseller?
Everyone is effected.
thank you don I have been in contact with Overclockers and sending the cooler back :( sadly they have no news or eta on replacement stock so I am short of a good cooler for my new system for the time being :(
hi guys so ive been looking at cpu coolers with my black ridge being returned and I found the Silverstone AR11 it comes in at 47mm and from reviews out performs the NH-L9i but some what more noise.
I got the i7-9700k 95tdp cpu and the AR11 reviews can cool it but I think the fan needs replacing I just think a more capable fan that delivers higher pressure and lower noise levels will improve things slightly.
so do any one have any suggestions for fans ?
I think I would just stick with the l9i, especially if you make a fan duct to pull cold air in from outside the case. You can make simple ones with plastic sheet and foam tape or people have 3d printed them.
Hi guys,
Have my Dancase in transit and am going with some recycled gear from my old build and some new gear. Have a Asus stix 470, and will be populating that with a Ryzen 1700 from another machine (unless a decent deal comes up on a 2600 in the next few days). I'm also recycling a 1080ti FE, and have purchased a SF600 for the PSU. For storage I'm going with a combo of a 970 evo and I'm hoping to recycle a couple of 500GB 2.5 SSD's if they do not interrupt airflow. Lastly I've ordered a L9A for the cpu cooler as well as a separate A9X 92mm fan for the bottom of the case (however I'm not sure about this if I want to use all my SSD's).
Now I'm probably going to have to undervolt the 1700 to reduce heat but people here have mentioned building a shroud for the V3 and cpu cooler. Are there any guides on this or anything I can purchase to pump out the air/suck in the air properly? Also, is my 1080TI FE going to case me problems (I've read that this can cause issues with the M2 SSD due to the heat distribution on the blower style cards).
Lastly, does the 92MM help much - I've seen people with two, should I order another to help?
Apologies for these noobie questions, first time SFF builder here and all that =)
Hi guys,
No need to undervolt the 1700, works great with an L9a, no need for a fanduct either. That said, I still made a fanduct for mine but I just like to tinker! I have 2 hard drives under my PSU too, I don't think the extra 92mm fan will make much difference for you as you have a blower style GPU.
so I went with the AR11 Silverstone cpu cooler in the end and the noctua 92mm 14mm fan. I am very happy with the cooler even tho I hate the brown fan lol the asus rtx 2080ti turbo is nice being a blower. I found the a4-sfx v3 very easy to build in and I havnt suffered from any thermal throttling yet from my 2x m2 drives
Has anyone tried putting a fan in the rear of the case on the bottom to get better air flow over the mobo?
I have a 92mm noctua as intake in the front hdd spot, but that doesn't seem optimal as it basically directs air over the power supply.
It looks like I have room for at least a 40mmx15mm if not a 60mmx10 - 15mm fan between the edge of the mobo and the bottom of the case.
When I'm running prime95 that lower back corner feels hot to the touch. I'm using the black ridge which has vertical fins so more upward airflow seems like it would help. (I'm hitting about 90c with avx workloads and sub 70c for others, so in general I think I'm fine, but I'd like to be safe here - 9600k, -30mV).
Noctua only offers a slim 40mm fan but not a 60. Any recommendations or experience here? Thanks!
Look at these two builds and go for a bigger fan, thats what I'm planning to do when I'm taking my mobo off the next time. I don't know the results for that fan though...
https://hardforum.com/threads/dan-a...in-the-world.1799326/page-349#post-1043562021
https://hardforum.com/threads/dan-a...in-the-world.1799326/page-369#post-1043951530
Wow those are interesting. From eyeballing it I didn't think the 92mm would fit, but I think I even have the same mobo as the first one.(oops I don't - they have an x299 and I have a z390)
Hello. I just got this case and im loving the size of it. Im currently using an strix 1080ti which is 2.5 slot. It fits in the case but without side panel on. My question is it worth it to trade my strix for founder edition? How hot does founder edition run on this case with lid on? Thanks
Hot. It sounds like a vacuum cleaner. I’d look for a quieter solution than the FE.
I've built another Dan case build for use when I'm stationed overseas in south east asia. My thermals are horrendous and I'm wondering if by going with a blower RTX 2080 Ti, i'll be able to achieve overall better thermals. Right now I'm using an 8800k with an Asetek 92mm AIO and have been using a Nvidia FE RTX 2080 Ti. I'm considering getting the ASUS blower model and moving the FE into another computer of mine.
Any insight on whether going blower will result in better thermals?
What are the temps for GPU and CPU? Please let me also know what test do you use to validate temps.
Blower style hits thermal faster and are much louder. Personally, if I could back from a 2080Ti FE, I would go with 3rd party, like MSI Duke 2080Ti 7C less under load and quieter.
The MSI Duke 20XX looks like a great successor to the EVGA 1080 Ti FTW3, one of the few 3-fan RTX cards that's not 3 slots, but will it fit length-wise?
Looks like a couple of people have shown they can fit card thicker than the official specs recommend [1], but how much tolerance is there in the length dimension?
[1]
No it won't fit. It's 314mm in length; the Dan A4 accepts up to 306mm. The FTW3 is 300mm.
Also it would be extremely tight in thickness at 46mm. The Dan A4 accepts 45mm; the entire clearance is 47mm but you need some remaining clearance. I wouldn't do it just for that anyway, the fans would be at 0.5mm of the grid, making turbulence noise.
Your best option for 3 fans is the Gigabyte Windforce (NOT the Gaming).
