Pics
Look what came in the mail today!
2M standoffs, so now I can try to use these instead of the alulminium rods to position the Noctua 40mm fan above the NVMe M.2 SSD to cool it
Can't wait to get home!
Do any of the following cards not fit in the Dan A4 v2?
Or, which do fit?
I'm primarily interested in the Strix 1080, I think.
It seems like the measurements given online are too close to make a call - so... better, I thought, for someone to confirm that they do / don't fit, based on their real-world experience.
- ASUS ROG Strix GeForce GTX 1080, 8GB
- ZOTAC GeForce GTX 1080 AMP! Extreme Edition, 8GB
- ZOTAC GeForce GTX 1080 AMP! Edition, 8GB
- ZOTAC GeForce GTX 1070 Ti AMP! Edition, 8GB
- ASUS Turbo GeForce GTX 1070, 8GB
- ZOTAC GeForce GTX 1070 AMP! Core Edition, 8GB
- ASUS ROG Strix GeForce GTX 1060 OC, 6GB
- ZOTAC GeForce GTX 1060 AMP! Edition, 6GB
PC-HAngover
I have taken some Car Wrapping foil from ebay here https://www.ebay.at/itm/25-EUR-m-Stickerbombfolie-Stickerbomb-folie-Autofolie-aufkleber-sticker/201332627898?ssPageName=STRK:MEBIDX:IT&var=500540343753&_trksid=p2060353.m1438.l2649
But it is not so easy to work with it like other normal Car wrapping foil like from 3M or other brands
sry for my english ^^
Also very interested in this!Dan, will you be selling v3’s usb cable separatedly so us with v2 (and v1) dan case can use it with the asetek 545lc aio???
Not bad!
I just pressed it firmly, I need to use a whole lot of force to detach it again, it's not going to move anywhere...
Do you also have the Noctua 40mm? I can only hear mine when it spins at 5000RPM, but that's only when running synthetic SSD benchmarks...
Probably none of the AMP versions will fit as I believe they are 2.5 slots wide.
I can tell you all of the EVGA cards fit, even the Kingpin with low profile pcie connectors.
Because EVGA cards are 2slot-ones with good cooling Solution!
To fit the EVGA 1080ti ftw3 into the case - you have to Open some screws of the case, but it fits!
I got the FTW3 in without removing any case screws, just unscrewed the riser, popped it on the card, then put the card into position and screwed down the riser. After doing it and routing cables, I want nothing to do with the Kingpin card.Because EVGA cards are 2slot-ones with good cooling Solution!
Not bad!
Nice! Any problems routing the cables?
Do you really need more 2,5 hdd?I think a missed opportunity is to be able to mount 2 2.5" drives in the front. It would fit if you turn them 90 degrees. Obviously would need some kind super flat sata riser cable (something like Apple use in their mac minis). I could probably drill some holes if I could get hold of such a cable. For the most parts, it's not really that neccesary, but..
1: I would assume no as its a product they are selling
2: buy a new cable and swap it.
2,5 HDD via USB, or SSD inside a USB external enclosure (10€)
No sata cable - No power cable - No dremmel or whatever...just USB and all the external 2,5 you deserve!
ebay, Alibaba, look on google. you can add a usb3-c if you want to mod one in.
HDD are loud even in idle. I have tried few and constant spining noise was very annoying. Now MOBO around CPU or CPU is most annoying thing but i limit CPU feq (by power plan) for web browsing and now whole pc is dead silence. It is because Dan case is build from thin panels so sould escapse easly . In my opinion is better to go with SSD even if SSD its not hi end ssd. Im using as secondary drive for storage Goodram Iridium Pro (MLC) and it has good TBW so even for storage it should be fine for long time.
im sure my google works just as good as your google....If you have a link to the new version that fits with the AIO that'd be great.
I don't even know what you mean by that either.
A lof of SFF enthusiasts like myself travel with their rigs so your solution is far from ideal. I want it all contained inside the case. So far the second SSD sitting on top of the riser in my case hasn't overheated and is working awesome. I'd too love to get 2 in the front of the case but we'd have to have some crazy power connectors too.
You don't even know what he means but you're asking him to google it?im sure my google works just as good as your google....
That's exactly why he's asking here.........yes because he knows what hes looking for, I dont
pendragon1 ...but reading your posts I don't believe that's the case (no pun intended).
no not part of the team at all, trying to offer help.[...]
